Floor Leveling Compound Question
Nat Robison
>I've just used a batch of floor leveling compound over a concrete floor in the basement for a bathroom I'm installing. I mixed it with the additive and the box said it should yield about 25 sq. ft of coverage 1/8" deep.
It was not what I was expecting. I expected the consistency of paint and you basically pour it out move it to the corners and it will flatten out.
I got something much thicker which had to be trowelled out, it doesn't look good, and will certainly need another application. It certainly wasn't going to level out to 1/8".
Any experience out there with this stuff and what did you do to make it work?
Re: Floor Leveling Compound Question
K. Goring
>I just had the same experience. I bought floor leveling compound when what I actually needed was "self leveling floor compound". It must say self leveling for it to flow on its own. In my area, Home depot carried it but Lowes did not.
Larry Clinton At Frankfort (Central)., Indiana
>I certainly am not a pro, but I used some on my 120 year old house living room prior to installing a floating floor. I purchased mine at the borg. I purchased 2 types: 1) The type you apparently have which is a "troweling compound" I used this in an area where there were gaps in the flooring and I needed to level the area. This was about the consistency of drywall compound. 2) The second type I purchased was a "pourable" compound. I used this in an area where the flooring was sealed but low. It had a thinner consistency, about like a thick syrup. I did have to do a little troweling but it leveled quite easily. You may have to look at a different compound - maybe at a different store.
I think you're both right
Nat Robison
>I do believe I bought the floor leveling compound and it was the consistency of drywall mud. I need the self-levelling stuff.
Damn those companies and their identical-sounding but very differently-performing products!!
Re: I think you're both right
>Your right Nate. One of my pet peeves is the labeling of "diet" and "regular" soda's. Diet Coke / "Zero coke" etc. I HATE the taste of diet drinks (my size reflects this), but I (and SWMBO both had purchased the diet in error. Some of the floor leveling compounds are labeled (as I recall) "Pourable" and some "Self Leveling". obviously both are the same thing - the other is either labeled "troweling" or is identified as such in the description somewhere. There is a big difference in the consistency. By the way they sure are proud of the product too, by the time you buy it and the "special high strength" thinning liquid, you could about shim the low spots with a good quality veneer for the cost.
David Hay @ Denver
>One thing to notes is that, from my one experience with the self-leveling compound stuff, you'll still need to have a straightedge or something to help it level. When I poured it out, it did indeed level, but it wasn't nearly as viscous as I expected and left rolled over edges (think, water beaded up on your car hood) Now it could be I didn't have the stuff mixed up right, though I did follow the instructions...but it wasn't as self leveling as I had thought it would be.
David
Same experience
>In fact, I used some (well, much more than "some") self-leveling compound (cement) this weekend. It was pretty frustrating. When it was poured out, it was too soupy to level with a straight edge. When I waited for it to firm up, I must have waited too long because it was too hard to level or even scrape much off.
I am sure that if I had experience with it I would know when to do what though.
It does "bead" up though and the center of the beads are definitely not flat.
Dave MacLuskie
>I used self-leveling cement in a small bathroom to level out the floor prior to laying tile. Very runny stuff. Make sure you fill all the gaps because it'll run out any holes. I put up cardboard along the open door. It set up amazingly fast, and this wasn't even the quick set stuff.
Sounds like that might be what you were looking for. I got mine at HD, I think. It was a "just add water" kinda thing.
Dave Donnelly
>Some of these products will set up slower if white vinegar is used in the solution.
In what amount?
Nat Robison
>What amount of vinegar do you suggest? Does it affect the flow-out or just retard imperfections?
VINDICATED at last!!!
frank shic
>folks, i'm so glad that someone brought this subject up. i renovating my guest bathroom two years ago and noticed that the floor wasn't perfectly level, so... i bought some of that floor levelling compound, poured it all over and watched anxiously as the hours passed and the stuff just stayed all HEAPED up in the areas where i had poured. well, it pretty much dried that way and then - genius that i am - i decided to pour yet ANOTHER layer on top of that. TWO WEEKS later, i had finished chipping all of it off with a hand chisel. my wife was slightly annoyed. i have never used floor levelling compound since then!
