Help - Router Problem
Charles Sharp
>The variable speed on my Porter Cable 7518 router is starting to fail. The slower speeds are the worst, it's almost like I could stop the bit from turning.
How can I fix this, or is it something that requires sending it into the shop.
Re: Help - Router Problem
John McGaw
>In any motor with brushes (and I've yet to see a router that doesn't have them) replacing the brushes and cleaning the commutator are always good first steps when any sort of start/run problem shows up.
del schisler
>look for the black bakelite screw caps Unscrew them the brushes are back of them With a spring attached to them see if they look some where about 1/4" or less mabe 1/16" Than time to change If you have a motor rewind place They may have the brushes Lot's of motors use the same brushes You may luck out and get the new brushes Also ask him if he has some spray cleaner It is best to take it apart and do it right But you can get a long with out that step Sometimes the armature should be turned down to debur it ?? Lots of steps that can be taken ? del
