Finished up another workbench
Stephen Kirk in Quakertown, PA
>I just finished and delivered this workbench. A friend of mine asked me to build him a decent workbench. He isn't a woodworker but needed something to do general work on, maybe attach a machinists vice too, provide some storage, etc. I made this from dimensional lumber with a solid core door for a top. The drawers are plywood with poplar faces. The assembly is all mortise and tenon (with stepped tenons on top to allow room for the draw bolts). The front and back rails are not glued into their tenons and are secured using the draw bolts. I left the top off during transport and delivery so we could get the bench into a basement. This was also my first contracted project which I was paid for, so I guess I'm now technically a professional (maybe once I get some more skills I'll start to feel like it, though).
Re: Finished up another workbench
A shot without the top
>I attached the draw runners using angle brackets. I actually put threaded inserts into the top of the draw runners which made things very strong, plus gave me a bit of wiggle room to adjust it true.
And the bench in place
>I just had to show that once in place the bench is already performing an important duty!
Oh, I should have mentioned above that I used locking rabbet joinery for the drawers and put a sliding try in one drawer for holding those small items.
It's no good..
Bri in Mtl
>Sorry but major error in not making the drawers tall enough for the beer bottles ;)
Nice job -what's the top made of?
Re: And the bench in place
Fred West in West Chester, PA
>Stephen, very nice job. If you don't mind the questionss, what did it run you and what did you charge? The lack of height for the beer bottles is truly distressing. :o) Fred
Re: It's no good..
>I'll have to discuss the option drilling a hole in one drawer and adding a drop in cup holder with my friend. That should meet the need quite nicely.
You know, that gives me an idea for my bench. Sort of an over sized dog hole designed for a 12oz bottle instead of a holdfast.
>The materials for this ran about $150 and I charged $200. Sure, it was a lot more than $50 worth of labor, but it's for a friend. If I was to guess at an actual price I'd think $350-400 would probably be reasonable considering time, the joinery involved, finishing, etc. I suppose you could drop the price by using lag bolts instead of draw bolts, not using mortise an tenon joints, etc. Perhaps even consider unfinished/unsanded. I planed most things smooth and figured it was good enough for a workbench.
Oh, and the top is a solid core door. They aren't the greatest for a woodworker (although I've used one for years) but they are flat and sell for about $50 at big box stores. Through on a couple of coats of poly and glue doesn't stick to it.
Amstel lovin' it, though! :.>)
>Good Afternoon Stephen,
The table looks as solid as a rock. Very nice job with the joinery.
George
Re: It's no good..
>It seems to me Stephen,
That with thirsty company, more oversize "dog holes" would be required, and you'll need two hold fast. :<)
George
