Re: OT Electric problems with contactor
Matt Prusik
>I have a slightly different take.
If this setup were mine and I saw what you're showing inthe picture, I would be inclined to replace all of the wire in and out of the contacter assembly with 10 gauge material.
Also, if I understand you correctly, seeing these connecters fry on the line side of the circuit tells me there might be somethong wrong with the motor on the DC. The advice you have gotten so far is excellent. But I would not ignore the motor if there are indications of a problem with the load side of the circuit.
I would check the motor and be sure that it's spinning freely with no physical obstrucions (dust and chips binding the squirrel cage) Also I would check to see that the bearings are good by trying to move the shaft of the motor back and forth.
I know that this situation can be frightening. But even if you have to do some disassembly to check out the motor, it's a good investment of time and labor to head off a potentially expensive problem inamsuch as it can be a big expense to replace a single phase, 5 HP, 220 volt motor!
Good luck and best wishes!
Matt Prusik
