Bending plexi
Bending plexi
Bending plexi
John D. Luke
>I need to bend some acrylic to a 3" radius to make a guard for a machine but I'm not sure about how to do this.
Was going to use the oven to heat the plexi and I'm not sure of what temperature to set oven at. (this will be done while wife is out shopping)
Heat the plexi at ___ degrees for ___ minutes take out and mold to form and let cool.
Anyone able to fill in the blanks?
Re: Bending plexi
Re: Bending plexi
Phil Joines Krum,TX
>280 degrees for 15 minutes per 1/4" of thickness is what I use.
Re: Bending plexi
Re: Bending plexi
>John I used to work for a sign company. We heated our plexiglass to 400 degrees and then put it in a form to be shaped. My own trick at home is to lay it over a piece of wood and when it starts to sag a little above that temp will work. Probably anywhere from 250 to 400 would work as long as you keep you eye on it. Too hot for too long and you can cause bubbles.
If it's a complicated shape, make male and female forms. If it's just a curve simply wrap it around a form and hold it in place until it cools.
Re: Bending plexi
Re: Bending plexi
>If the piece is larger than the oven you have to heat it in, you can use a hand-held heat gun (not a hair dryer), but you have to keep it constantly moving to prevent spot overheating, and work to get the material at an even temperature across the entire bend line.
I made some basement window covers that needed bent flanges, but learned the hard way that the plastic will fracture at a cool point along the bend line; especially at the edge of the sheet! |:-{
mm
Re: Bending plexi
Re: Bending plexi
Keith Newton
>It seems like they make a crayon that you can put a mark on the sheet, and when it changes color, the temperature is just right.
Re: Bending plexi
Re: Bending plexi
Pete LaBelle
>Suggest not using "plexi" (acrylic) for any guards. Acrylic is brittle and will shatter upon a hard impact. If you want your guard to truley contain the danger, use polycarbonate (Lexan).
Although polycarbonate would be the better choice for any guard, acrylic is better than nothing.
Note: Pleixglas and Lexan are only trade names.
Re: Bending plexi
Re: Bending plexi
John D. Luke
>Thanks for your replies.
Right after I posted the question I had an idea and went to ebay and looked for an acrylic tube and found one with a 3.75" ID 4" OD by 11" long, exactly what I need, just cut it to length.
It was a "buy it now" so should be on the way to me now.
If any of you are wondering what the guard is going on, it is for an old Rockwell Over-arm router.
Thanks again.
John
Re: Bending plexi
Mickey Mouse . . .
s.mackay@worldnet.att.net
>Method. I got tiered of paying Craftsman for my belt sander dust chutes. Took a piece of PVC pipe slightly smaller than the 3". Clamp one end of the stock plexi to the pipe and use a propane torch with deflector and WARM the stock. Work your way around the bend a couple inches at a time, clamping as you go. Super Glue an end of flat plexi on the side of the curved " chute ". Blive it or not, it holds well. To finnish it off, " Pop-Rivet " an old feeler gauge leaf into the inside of the chute to hold the dust collector hose between the plexi and gauge leaf. Just leave enough plexi at the bottom of your curve to fit into the wrench holder bracket on the machine base. New dust chute for the price of the propane and its tougher than store bought.
Re: Bending plexi
Re: Simple- buy Lexan instead of plexi
Ron Hildreth, Alta, Iowa
