THE WOODRAT IS BACK!
Slots for drawer bottoms....
>easy way is on the tablesaw - dado and go. It does leave a "hole" on the end in the tail/pin area or where the finger joints are overlapped. So, I suppose I could make a jig and use a plunge router with a 1/2" bit (for the 1/2" plywood bottoms) or a 1/4" bit (for the 1/4" plywood bottoms). What do ya'll say?
Re: Slots for drawer bottoms....
J D Thomas
>I do it similar, but use my router table and stop blocks. I hate those show-thru holes.
J D Thomas
ThomaStudios
Jim Dillon
>JL,
You could attach a separate drawer front that would hide the holes - at least on the front of the drawer. That is what I did on my shop drawers for my workbench. Worked out just fine. Just remember to cut the sides of the drawer shorter to accommodate the drawer front thickness. On-the-other-hand, the router approach eliminates the problem altogether.
Jim
>Good Afternoon JL,
I also use a table and stop blocks. Alternatively you can draw a couple index lines vertically on the table fence and lower/raise the blanks at the lines. I think it would be a hassle with a plunge router out of the table.
George
Dave Bair, Eaton Rapids, MI
>I assume you're not talking about through-dovetails. I cut the drawer bottom slots after I cut the dovetails. Center the slot on the lowest full pin of the drawer side piece and it'll be covered by the drawer front; the slot in the front will be covered by the pin on the side piece.
