Beis. Fence - Sticky Friction Problem
SanMan
>I adjusted my Unisaw fence the other day to be parallel with the sawblade and now it moves alot harder than it used to. It takes a pretty good push to move it!
I used to get some additional "noise" as the tail end of the board was cut and tried to exit. The "noise" was the sawblade brushing back against the wood, thus it was obviously not parallel.
Ive never been really happy with the way my fence slides to and fro...but now its worse. I dont know what to try next.
Suggestions?
Re: Beis. Fence - Sticky Friction Problem
>As I recall it has two set screws which are on the back side of the "T" which adjust the fence angle.
Try loosening both setscrews which align the angle of the fence a little bit (fraction of a turn). Adjust both the same amount and recheck the alignment of the fence to make sure it is correct.
I think you probably tightened them both too much when you adjusted it so the fence is too tight on the rail now.
