JET tablesaw with split v-belt pulley - - update
Pete LaBelle
>Received the new turned-steel v-belt pulleys for my saw (Jet Contractor's) on Friday and installed them on Saturday. Putting the segmented belt back on and firing up the saw, it ran well, and it appears to run quieter too.
Started to rip some 3/4" oak again (yup, the blade is sharp) at a high rate of feed and noticed the blade start to slow, so the glue jug went back on the motor and the saw is back at full performance.
I think the old pulley(s) were slightly out of true and/or the fracture may have been there for a while. There is a reason better saws come with steel pulleys, and upgrade pulleys are available for those saws with aluminum or zinc pulleys.
Local Woodcraft store had the pulleys at my door 3 days after I ordered them.
Pete
Re: JET tablesaw with split v-belt pulley - - update
arw01
>Greg, do you have the part number from woodcraft for the upgrade pulleys? My Jet contractor also has the metric sized shaft. When I replaced my bearings I broke the pulley getting it off, but had to put buy another jet factory one as I was unable to find a steel pulley to replace it.
Alan
Chuck Lenz
>When you say the saw blade was slowing down I assume you mean the belt was sliping since you added wieght to the motor. My guess is you may need more links in your belt to get a better tilt on the motor. If you do this ofcourse you need to watch the belt with saw OFF in all positions of the blade to make sure the belt doesn't rub on anything before trying it. Or maybe you have the wrong width of belt or the wrong profile belt for your new pulleys. All I know is it shouldn't slip, especially when only running a 3/4" board through the saw. You say you were running the boards through at a high rate of speed. Not a good idea for several reasons, but I won't go there. I have a Delta Contractors saw with the same brand of belt that you have plus I wired my motor for 220 volt. With just those two changes it has improved the saws performance greatly and I highly recommend it. Less vibration, smoother cuts, and lots of power. Before I switched from 110 to 220 depending on what I was cutting the saw would occassionally dim the lights in the shop or even trip the breaker.
Pete LaBelle
>I don't know the part number off hand, but the arbor pulley was a 14mm bore x 55mm diameter, and the motor pulley is 5/8" ID x 2-1/2" OD. Contact a Woodcraft dealer in your area. My pair was $30 shipped to me directly.
Pete
arw01
>A search on Woodcraft's website comes up with nothing
Arbor
pulley
Don't trust my local woodcraft to get the order correct yet, that is a special little beast the metric one.
Alan
