>What is your method for securing mirror and glass. I've made the frames and rabbeted the back. For the mirror(1/8" thick) I am going to back with 1/4" play. What's the best looking way to secure this - trim strip with screws all around, clear silicone to hold the mirror to frame and then more silicone to secure the play back to the mirror? For the glass, I think I'll use wood trim strips. Appreciate your experience on the best approach.
>If you use silicone adhesive, it might be tough to get the mirror out without breaking it. Plus, if you are going to see the inside of the door, it's going to look pretty sloppy, IMO. For the best work, I used to make little quarter round moldings and secure them with tiny oval-head brass screws drilled through the moldings at a 45° angle so they would essentially toe-nail (toe-screw?) the molding into the rabbet. For an added touch, buff the heads of the screws.
Old-time craftsmen used to nail their moldings or skip the moldings and glaze the glass or mirror in with glazing compound. Nailing is always hair-raising because one slip and the mirror is toast, but with a modern pin nailer, it is a relatively safe option. To remove pinned moldings, you can pry them loose with a putty knife. This approach saves you all the drilling and counterboring and pilot drilling and screwing of the screw method.
>Take care that if you you use an adhesive on the back of the mirror that is specifically says it is OK for use on mirrors. Specialty products are made for that application. The incorrect material can cause the mirroring to deteriorate over time. Remember too that it only takes a few dabs to keep it from rattling as long as there is other structure to hold the weight.
