REAL MILK PAINT
Best glue for Plastic? OT (refrigerator parts)
>One of the boxes or trays that goes in the door of my frig broke. It�s a plastic "box" that hangs from some haunches formed into the door liner. Turns out it hangs from the top lip of the tray and its only about a 1/16" thick. A "u" shaped piece broke out. Obviously if I glue it back, the glue has to be stronger than the plastic. No easy way to reinforce it, its all formed and shaped. Short of buying a new one, anybody got any suggestions?
Re: Best glue for Plastic? OT (refrigerator parts)
Joe in a Cleveland suburb
>Barry,
You might find something at thistothat.com
Joe
not easy
Bill Tindal, E.TN
>Different plastics require different adhesives and some are impossible to repair. Step 1 would be to test whether a proposed adhesive will bond. Put some on the drawer and see if it sticks after curing.
I'm surprised that the drawer cracked. They are typically made from high impact plastic and near impossible to fracture. It may indicate some defect in the plastic.
A possible approach
>As Bill menitoned, those things are usually made of high-impact plastic -- usually polycarbonate -- that requires some nasty chemicals to bond it together. I don't know how important aesthetics are to you, but you might be able to effect some kind of mechanical connection, such as with PC-7 adhesive. If you don't have room to build up a lump of this heavy-bodied epoxy, you could try attaching a piece of aluminum or something to the existing plastic.
I've not had good luck with repairs like this.
Re: not easy
Larry Clinton At Frankfort (Central)., Indiana
>I've had pretty good luck with the 5 minute and 1 hour epoxy kits offered at Wally World. My son has several aquariums and we found a "protein filter" a few months ago at an auction that was broken into several pieces. I repaired the housing (made of what appeared to be acrylic). I first tested it on an area and it "bit" into the material. I carefully clamped and epoxied it together. After the re-assembly, I used CA glue to cover and seal all the little joints. He has used it on an aquarium for about 6 months without any problem. We also repaired a broken trim section from a vinyl window frame using clear PVC cement. It also held well. I would test these adhesives on your shelf in an innocuous spot and see if they adhere well. If they don't the material is probably lexan - if so it requires a special solvent adhesive and should be "baked dry" prior to repairing. Couple links attached with information on solvent bonding acrylic and polycarbonate. http://www.acrylic-designs.com/plastic_FAQ's.htm http://www.craftics.com/products.cfm?Category=80
Curly Smith
>From Plastics FAQ
"For polycarb you want to use weld-on #4. For acrylic, you can use weld-on #4 or #5"
You can buy the stuff here:
RPlastics Store
You might also be able to buy it locally if you have a plastics retailer.
Re: not easy
Glenn Madsen near San Francisco
>We've had some crack and break. I always either ignored the problem, or bought a new part. With the load factor, I can't see a glued part surviving long. And we have a pretty good source of parts, if you're patient.
Contact an...
Tom Dunlap in Atlanta
>...appliance repair shop to see if they have a junked fridge that you could scavange a drawer.
Plastic welder?
Kneale Brownson in Northern MI
Had the same problem...
Hoa Dinh in Alameda
>a year or two back. I first tried plastic glue from my local plastics store. The glue line broke about a week later. Then I tried slow cure epoxy. It lasted for two weeks.
I then glued the plastic back with the same expoxy glue. But this time I enforced the fix with a strip of 1/16" thick 3/4" (or 1/2", I don't remember exactly) angle aluminum, attached with #4 nuts and screws. I did it for both sides of the tray.
I think the tray will now last several lifetimes of the refrigerator.
-- Hoa
Whoa! Just called or price on part......
>I think I will be opening the Irby Appliance Repair Shop on this one. They wanted $37 for the little bin, plus shipping. I was thinking 15 or 20 bucks and I would buy it and not try to fix it. I will be sculpting a piece of lovely matching white aluminum with a baked on finish (coil or gutter stock) to fit and gluing it with epoxy.
Tom Minehan
>I have had success using Loctite "SuperGlue for Plastics". Butt jointing did not hold up but bridging the joint with another piece of plastic has worked well. I got the Loctite at Lowes.
I've fixed these with 5 minute epoxy
Rob Sandow
>It's a bit ugly but so far holding up well.
Rob
Lee Gordon
Lee Gordon
>I'm not sure what sort of adhesive you can use to make the repair but I'm wondering if, once you select the appropriate product, you could reinforce the repair with fiberglass drywall tape.
