Sawstop
Gary Tenney
>I am considering this purchase and was wondering if anyone owning one likes the fence. Would it be worthwhile to put a different fence on the saw or is the factory one top shelf? Tanks!
Gary Tenney
Sawstop
Gary Tenney
Gary Tenney
Re: Sawstop
Patrick Schupbach
>I have not used this saw, but the reviews say this is a very nice saw, maybe the finest available. I think it would be safe to say, the fence would be no exception.
Re: Sawstop
Brian in Sandusky, OH
>I own the SawStop, and have had no complaints at all with the fence.
I often use my friend's Unisaw. He has a Beismeier fence, which is basically identical to the Sawstop fence, from what I know.
Bottom line, I use both fences frequently, and I can't tell any big difference between the Beismeier, and the Sawstop fence. They are both great.
Re: Sawstop
Ted Wong
>The Sawstop fence is a copy of the industry standard Biesmeyer and it performs its tasks in much like the original.
Re: Sawstop
Dave Mount
>I have their saw. The fence is a Bies clone, well built. I haven't actually measured the deflection under a side load, but it seems mighty stiff.
My previous saw was a Unisaw with a Unifence. Just because the feel of a Bies-type fence is different from the Unifence, it took a little getting used to. I suspect that someone that used a Bies previously wouldn't notice any difference. It's amazing how your TS becomes an extension of you, and you know instinctively where to reach and the quirks of everything. When you get a new TS (any TS, not just the SawStop), things feel a little unfamiliar at first, like you have to think about things you previously did without having to think about it.
Regardless of the opinions that get thrown around about the "politics" surrounding the saw, it is at it's core a very nice saw, I think you'll like it. I was very happy with my Unisaw and wouldn't have changed if it weren't for the safety features of the SawStop. However, the SawStop is more saw than the Unisaw, even without the blade brake. You definitely feel like the additional cost gives you a lot more than just the blade break.
There's one thing about the dado setup you should know that wasn't clear to me before buying. I had the impression you could run a dado blade without the dado brake if you were willing to disarm the safety system. This is apparently not true because the initial diagnostics will detect a fault if the regular brake is used with a dado set and the system will not let you fire it up. So, spending the additional $90 for the dado brake cartridge is a requirement if you intend to run a dado set in the saw.
One other thing is that I don't believe you can run a molding head in a SawStop. I didn't do that very often with my Unisaw, but I did occasionally use a molding head to make beadboard paneling. I'd have to borrow someone else's saw to do that now.
Best,
Dave
Re: Sawstop
sawdustdan
>Like everybody said basically a Bies fence with 3 differences from the Bies I had before.
1. Can adjust fence face perpendicular to the table.
2. Internal adjustment screws for 'flattening' the fence face
3. 2nd hair line pointer for setting left of the blade cuts
Re: Sawstop
Don Bullock
>Remember that the fence doesn't "come with" the saw. It is an extra cost. Having said that, the SawStop fence is excellent. I, however, opted to buy a custom Incra fence for mine. As soon as I can, I plan to add a router table to the saw so I can use the Incra for both.
Re: Sawstop
Ray Newman
>Adve M: is there a " shelf life" (or expiration date) to the brake catrridges?
Thanks very much to all
Gary Tenney
>I appreciate all the response to my querry and am mostly decided to stick with the manufacturers fence. Was there a particular reason you opted for the Incra fence? Thanks again to everyone!
Gary Tenney
Re: Sawstop
Dave Mount, NE Minnesota
>I asked about that and the answer was no, they don't degrade in storage as long as they're kept at reasonable temps.
Best,
Dave
Re: Sawstop
Jim Moore
>What is so cool about the Sawstop modules is that in most cases, the factory can tell what kind of wood you were cutting when the module fired. The electronics are very sofisticated. This saw is really great.
