ADVERTISE HERE - FREE TRIAL
Table Saw Zero Insert
Ray Binnicker
>I watched an episode of NYW last week and Norm was doing "tablesaw 101". He showed a zero insert of which only a strip in the center of the insert needed to be replaced. Does anyone know where I can locate one?
Ray Binnicker
Re: Table Saw Zero Insert
Conspiracy Theory 101
Rod Peterson -- Ormond Beach
>I had that question asked of me a couple of years ago, and in trying to run it down found that there is zero web presence of the device (I call it an oak insert insert on my Norm's Tools website). I searched again just recently, wanting to upgrade the picture I have. Nada, zilch, bupkus.
I did find that there are now a couple of substitutes (not quite as elegant, in my opinion) available which leads me to believe that someone with semi-deep pockets might have developed such a substitute then turned around and bought the rights and inventory of the original and pulled it out of circulation entirely. I had that experience with an amateur radio accessory several years back, and posted about it a few weeks ago, I believe.
I have some aluminum plate and a saw blade that needs to be sharpened anyway and I've thought about making my own. Lee Schierer did that four or five years ago for his Craftsman saw. I actually had it in my hands at Five Barns or Indy (can't remember). It was very nicely done.
Rod
Re: Conspiracy Theory 101
Vijay Kumar
>I think this is what you are looking for
http://www.leevalley.com/wood/page.aspx?c=2&p=55985&cat=1,41080,51225&ap=1
Hope this helps
Vijay
nope
Joe Piotrowski - Chicago Burb's
>I had/have one of those. picked one up for my jet TS. I don't use because the blade won't sink down far enough on my saw.I also used on on my craftsman saw I once had.
IMO. over it's not worth the price. the inserts are not easy to change out without fiddling with them. to I picked up my jest one on the clearance table a woodworking store. probably Rockler.
I prefer buying the 5-10 dollar MDF inserts personally.
Chuck Lenz
>I ran across one on the net just the other day by accident. I can't remember the name of the company but it looked like a aluminum frame with about a 2" hardwood strip front to back. The company was no longer takeing orders and was up for sale.
Re: Table Saw Zero Insert *LINK*
Dave Peebles Lyons, Ohio!
>Hi Ray,
I bought mine several years ago. It was made by Wood Dynamics. I did find their web site. But as mentioned, it seems they are no longer taking orders.
Mine works great. The best way to put the initial slot into the insert is to use a 7 1/2" blade. The clearance on my Craftsman tablesaw would not allow for the use of a 10" blade for the initial cut.
I do seem to remember that Bestwood tools used to carry the insert, or something very similar. But I do not see it on their current web site. You might try contacting them to see if they still have them for sale.
www.bestwoodtools.com
Best wishes,
Dave
Link
>Ray It would be very easy to build one if you have access to a router. I would put in a dovetail insert. Double stick tape your old insert to the wood you want to use and then route the outside. I put in setscrews to adjust the height. I just make a whole blade insert and run the blade up through it for zero insert blade hole. I have a small anvil that I can lay on top of the insert to keep it in place while I run the blade up. After that I remove it and enlarge the hole by a smidgen with a flat file. It keeps the blade from rubbing it.
Many of us make inserts for our saws
>I have looked at those things and can not get myself to buy one. Seems too expensive and not as useful as it seems at first.
I've been making them for 10 years or so. I make a few in bulk and they last a while. Making a few at one time does not take much longer than making one - typical setup issues.
I use 1/2" (12mm?) Russian birch (low cost baltic birch). I use scraps and run it through the table saw to get the width EXACTLY the same as my existing insert.
I trace the existing insert ends onto the blank.
I use a 1/4" router bit to create a slot for the saw blade on the bottom side of the insert - not all the way through, just 1/2 of thickness of blank. This makes it easier to cut the starter slot later. It does limit the thickness of the insert at the blade however.
I use a bandsaw or jigsaw to cut the ends close and either route (using the original or a good copy as a template with a bearing on the table) or sand to the line with a disk sander. The radius does not need to be exact but a tight fit is safer.
I cut a slot for the splitter with either a router or bandsaw.
I drill 1/16" holes where the 'landing pads" in the saw are placed for the height adjustment screws. I insert #4 flathead screws from the bottom to adjust the height - they are cheap and easy to use.
*** DO this (below) at your own risk - I've done it many times and am comfortable with it. ***
I lower the saw blade all the way. put the front edge of the insert into the saw, put a Griptite magnetic featherboard onto the very end of the insert so it holds it down. The Griptite is a strong magnetic device so most of it is on the table - just an edge is over the insert.
I lower the back side onto the stopped blade gently and turn on the saw. I push down on the back side when the blade is going, using a piece of wood, standing to the side. This creates a starter slot. I do not cut a full slot at this time. This is the only possibly dangerous step so be careful and use common sense here. I am never where I can get hit by kickback, but have never had any safety problem or even a hint of a problem doing this. I am still really careful. One caveat - if there is any pressure on the blade when the saw starts, the blade may not start to turn so make sure there is no pressure on the insert at the start.
I also made several for my dado blade (several widths). These are easier to cut the slots with since the dado blade does not touch the insert when the blade is all the way down. I usually use my table saw fence to hold down one side of the insert and a Griptite on the other side.
This is what I do - may be every other year or so.
Re: Many of us make inserts for our saws
>Have a template of my saw's blade window that I made from MDF years ago to make these things. Cut some good flat 1/2" ply close to the size, stick the MDF template to the top of the ply with carpet tape, and trim to size in the router table using a guided flush-trim bit. Then drill four small holes for the leveling set screws and you're ready to go. Takes all of about 10 minutes. I've got 10 or so to fit different widths for the dado set plus several for the rip and cross-cut blades. Total cost $0.00 because made from scrap destined for the burn bucket. Of course, if you want the spiffy "look" of an aluminum/wood throat plate, I shouldn't pursuade you from spending your money, but pretty is as pretty does, and mine do exactly what they're made to do.
mm
Larry Clinton At Frankfort (Central)., Indiana
>I got a little fancy last time I made inserts for my left tilt Unisaw. I had some left over Baltic birch and some grey Formica left over from my Router table. I ripped the birch to width, rough cut the ends a little over size on the band saw. I glued about 8 blanks on the Formica with contact cement, then cut them apart with the band saw. I used the metal insert that came with the saw as a pattern & with a pattern bit routed all to exact size. I then counter bored the spots for the bottom and side adjustment screws and inserted short screws in each position. I adjusted all to fit the saw level and tight. I installed an 8" dado head in the saw and put in an insert. I put the fence over the insert and raised the dado (little over 3/4" wide - didn't measure) into the insert until the groove was about the same depth as the Zero clearance that came with the saw. Took a little time for the first one as I had to remove it 3 or 4 times to determine how much to raise the cutter. I then counted the turns of the blade raising mech. and did the rest. I spent about 4 hours making 8 (with about 3 extra unfinished blanks). At about $18 apiece in the catalog, think it was time well spent. Sides I like mine better and I was doing something I like to do. Use about 2 or three a year. after the Zero clearance is sloppy, I use them for dado heads.
I've got one of those....
John in New Mexico
>They're nice for making UHMW plastic inserts instead of oak, as the humidity swings we get out here can cause a wood insert to get stuck in the saw. Bought it at Woodcraft maybe 5 years ago. I think the company went out of business or stopped making them, as at $100 or so, they were the priciest insert on the market. Last time this subject came up, someone posted a link to a similar (or same) product, only available through the manufacturer, with only line drawings of the product.
John
>You guys are using screws for adjusters? Wonder why I never thought of that? What I did was glue a thin strip of wood on the bottom of the plywood (scraps of cheap Baltic birch) and then run them through my Performax to sand them to the right thickness. Actually had not planed on the sanding step, but they were a bit tall and it worked great.
I made about a dozen. When the slot gets worn, they get "reassigned and become Dado inserts. I don't remember any trouble cutting the slot. Wonder if my blade retracts far enough, or maybe I started the slot with a single dado blade (8" on a 10" saw) but did not raise it through the insert. I may have put them in one after another and plunged the blade partially into all of them.
Re: Rod...
Dave Arbuckle, Plano, TX
>I don't follow Norm, but I've been told multiple times that the one he was using was a Wood Dynamics, same as I use.
Does this web site turn the trick for you? Wood Dynamics.
Sawdust Everywhere!
>Ray,
I believe this is what you were looking for.
As the others have mentioned, the company is not taking orders anymore at this time. You may want to bookmark this page and check back once in a while.
When I last looked at the website when it was taking oders, I believe each throat plate was about $110 for most table saws, if I do not remember wrongly and they were selling the replacable wooden insert for $5 each (2 for $10). Heavy initial investment but looks nice and works great.
Hope this helps.
http://www.wooddynamics.com/
Re: Pre-cutting
>I used my dado stacked to 1/2" to precut a clearance groove in the underside of each blank. That way the 10" blades cleared when fully retracted. The set screws are great for leveling and to keep the blank from wiggling in the top. I also use a couple of strips of aluminum HVAC tape to tighten up the plates at the sides. Works great for taking the slop out of miter gauge runners as well.
mm
Ray Binnicker
>Thanks for all the input, folks. The Wood Dynamics one is certainly the one shown on NYW. Like most of ya'll, I've made mine too, from plexi glass, plywood, etc, for years. Seemed like the Wood Dynamics one would be faster to change since all you had to do to change an insert was slide the strip out and slide a new one in, not having to worry about new set screws each time.
We'll talk again later.
Ray Binnicker
Lee Gordon
Re: Rod...
Lee Gordon
>I remember seeing that type of insert at Woodcraft a couple of years ago (don't remeber if they still had them on my most recent visit). Unfortunately, it appears that the only thing Wood Dynamics is selling these days is the company itself. Anybody got a spare 70-grand? You could go into the zero clearance insert business.
I made a stack of inserts from some pieces of scrap Corian that a local kitchen/bath counter-top fabricator was kind enough to let me have.
My insert
Lee Schierer - McKean, PA
>Yes you did Rod. That was immediately after it had been completed.
I had a friend at work make one for me in return for a favor I did for him. It is made from aluminum and the insert is 1/4" maple. I use a thin kerf rip blade and a regular kerf cross cut so I can get two uses out of each insert before throwing them away. Mine fits a craftsman table saw. I have a cad drawing someplace if anyone has access to a friendly machine shop or machinist and wants a copy. They will need a 45 degree dovetail cutter to cut the sides of the slot, which many shops do not have as a standard cutter. My friend passed away unexpectadly shortly after he completed this for me so I think of him often when I use it. I do know a machine shop where I could get one quoted, but have no idea what it would cost, if someone is interested.
Lee
you can route aluminum if you like.
ed snow
>why not just go to your local scrap yard and buy some aluminum to make one. you can also bandsaw and tablesaw aluminum. just lube everything with tallow first.
Rick L
Re: Negative hook blades...
Rick L
>I agree with the simplicity of machining aluminum with regular wood tools. Negative hook table saw blade is the best. I've cut miles of non-ferrous with such a blade. However I find only the harder aluminum alloys need lubrication and not necessarily tallow. WD-40 and most any other lube will work. I doubt many will grasp the idea of making your own throat plate of aluminum. As cool as the web is, there is more bad info than good info and most folks can't tell the difference anyway.
