Wipimg on Poly
Don Henthorn
>I remember several years back, Michael Desdner, Jeff Juit, or somebody had an article about wiping on poly full strength. I can't find it. Anybody remember?
Wipimg on Poly
Don Henthorn
Re: Wipimg on Poly
Dave Bair, Eaton Rapids, MI
>Don't know the article, but I do it all the time. It builds faster than thinned poly but slower than brushed-on. It dries fast enough to get two coats a day. The best part is no bubbles or brush marks and super easy clean up.
Re: Wipimg on Poly
robert davis
>suggest you try poly sold as wipe on poly. works great..minwax and many other brands
Re:I like the Watco Wiping ....
Jamie Donaldson
>...Poly better than the Minwax-has more body and builds a bit faster.
This? *LINK*
Hoa Dinh
Dresdner's Article
Thanks, Hoa. That was it.
Don Henthorn
I have been mixing poly and naphth for years as
Don Henthorn
>a wiping poly. I was just looking for a faster build. Dave, I'll give it a shot. Thanks to everyone for their responses
Re: I have been mixing poly and naphth for years a
>Same here Don,
Ever since reading a thread by Jim Kull on the Wood Forum a thousand or so years ago, a 50/50 mixture of naptha and poly have been my standby. Altering that ratio in favor of more poly seems to build faster/dry slower. A friend gave me some Bartley's gel which also works well so long as you wait until your next birthday for it to dry. I like the 50/50 mix and use multiple applications.
George
Re: Wipimg on Poly WITH FINGERS
del schisler
>i have put on poly with my 2 fingers lots of time No brush marks or finger marks you can put it on and wipe with fast finger stoks You can get it on real good It take some doing for the first time to get the hang of it It get's to where it look's right and than Just take the 2 fingers and do a swipe No marks I have done tables so it is just not a little board thing
eliot d
>I usually use Watco oil on my lathe- turned pieces. I Just power sand them to 1000 (easy on the lathe) and wipe on the Watco. I usually get a nice oiled wood look. Today I happend to see some cans of Watco wipe-on Poly (gloss, semi gloss, etc.) . What look do you think I would get if I used the same regimen with one of these?
Different animals
>Polyurethane finishes build quickly to a thicker film than Danish oil finishes, which reside mostly in the wood and build only very slowly. Why not try wiping some poly on your next project to see if you like the way it looks and handles?
