Questions on "truing up" a table under contruction
>I have been making a 42 by 70" table and posting questions and you guys have been very helpful, as usual. I built it with M & T joints from the rails to the legs. Careful to cut every thing square and true. Assembled the table frame with a single bar clamp on each side to pull the tenons tight into the mortises. The shoulders came up nice and tight and looked good. The diagonals at the tops of the posts were off by a 1/32", so I left them alone. The lengths of the sides and ends were as accurate as I could measure. The table frame sat flat on the floor (As if the floor were level, let's hope, it a slab) The legs are 3 3/4 square at the top with a turned section.
Now for the questions: I turned the table upside down to prepare for the top and happened to pull a tape on the bottoms of the legs. The lengths and widths are off maybe 5/16" and so are the diagonals. Is this "normal". The error is not visible and I can't see how it will ever affect the function of the table, but my curiosity is up. Does anyone else ever try to square and true both the top and bottoms of the legs? Has anyone else even checked?
