Tenoning jig for table saw
Gerald Caryl
>I have a prodject tha reguires alot of tenon joints. I am leaning toward the Shop Fox Jig as apposed to the Delta or Inca ect. What are your thoughts as the best out there? Thanks Gerry
Gerald Caryl
Re: Tenoning jig for table saw
mdclor
>I have one from PowerMatic and it does everything I need. I haven't used any others for comparison however.
Happy hunting,
Merle
Larry Clinton At Frankfort (Central)., Indiana
>I looked at several at Woodworking shows, at Rockler and a couple other woodworking stores. IMHO I didn't see any differences beyond the paint color and label. I bought a generic at Rockler on sale for around $50 - After aligning it, the unit works perfectly. If you can find one on sale (of any brand) I would buy it.
Jesse in New Mexico
>I'm with Larry. The all seem pretty similar. I have the Delta and no complaints. If I were buying, I would probably go for the one on sale.
Dautterguy
>I would check aroud a little more before I bought a SHOP FOX. I purchased one(Tennioning Jig),and could NOT get it to be true to my Table Saw Miter slots, had quite a bit of movement both horz. and vert. I went with the General,very stable,a little bit more pricy but well worth it.
They all appear to be similar....
John in New Mexico
>probably at the very least the same castings with a few different features added for different brands. There was a thread a couple days ago about aligning them. The name brands seem to be better set up out of the box, but if the $$ is an issue and you don't mind spending some time tweaking, go with the cheaper one.
I've got a Delta, but these days prefer to cut my tenons with the bandsaw. I keep the jig around for the rare weird tenon that I can't do any other way.
John
>Good Morning Gerald,
I have the Delta. It is worth having. Mine works well, but so do the others at a lessor cost. I'd buy by price.
George
I've found it pays to check out any tenoning
Forrest Addy
>I've found it pays to check out any tenoning jig with regards to squareness and parallelism of its presentation of the work to the saw blade. This is a 10 minute job if you're familiar with dial indicators or maybe an hour if you are not.
Regardless, a little premliminary checking of the morticing jig will save endless hassle if you tend to make tables and M/T carework that hits on three corners instead of all four.
