Rockwell Int. 10" motorized saw, Model #34-345
Ed Blickhahn
>I purchased a used saw and the blade wobbled when in use. I cannot remove the blade because the washer refuses to come off the spindle. Is there a 'trick' to this? Is the washer threaded? Any advice would be appreciated. There is no manual with this saw. I am also trying to get my hands on both an operating manual and a parts manual. Ed in Alaska
Re: Rockwell Int. 10" motorized saw, Model #34-345
>Can't help you with removing the washer, but you can go to Delta Tools (google them under "delta tools") go to the parts site and you can download the parts list and manual. Delta and Rockwell are interchangeable at that point. You will need the number you posted.
To remove the washer, I would try holding the shaft or blade and using a large pair of pliers or a pipe wrench to grip the rim of the washer and unscrew it a half a turn and then tap the "high" side toward the blade to see if I could straighten it up. But don't listen to me, there might be better ways and I just made that up.
PS, I ahve a Rockewll 34-338 Contractors Saw
>and the washer is not threaded. Its a stamped steel washer and it does have the habit of getting itself sort of cross threaded into the threads if you are not careful putting it on.
And, On the Delta site you will have to "Sign Up" to use the parts section, but it is pretty painless and they don't seem to pester you.
I have worked around some guys
Keith Newton
>who would tighten the blade nut so tight, that the washer would get deformed. Under the nut. It would become indented under the nut, then the middle part which is formed would get faired out, causing the outside edges to flair back away from the blade, actually giving the blade less support, not more.
It is really unnecessary to tighten the blade that much. I suppose some people fear the blade coming off.
Maybe the previous owner was one of those people, and the inside diameter of the hole got peened smaller.
As far as removing it, I would start with an old chisel, driving it under the edge of the outside washer, working my way around. If this doesn't work, you may have to take the trunion out then have someone press it out for you.
