cutting plexiglass
david b
>What kind of blade should I throw on my table saw to cut plexiglass.
thanks,
db
cutting plexiglass
david b
thanks,
db
Re: cutting plexiglass
Ray - SW Ohio
>I used an 80 tooth blade. Keep the feed steady to prevent burning.
Hoa Dinh in Alameda
>I use either an 80T fine cutoff blade with negative rake angle. That's what my local plastics store uses.
If I'm lazy to change blades, my 50T combo will do the job just fine. The cut will be a bit rougher, but not by much.
Then I finish the cut with sanding cloth.
I've heard people cutting plastics with a blade mounted backward. DO NOT do that with a carbide-tipped blade. It is dangerous. You don't want the tips flying out on you.
-- Hoa
Re: Plexiglass Blades
Charles M
>Quite true about the negative hook and about the danger of turning the blade backward. Most dedicated plastics cutting blades are triple chip grind with low or negative hook. The LU94M010 that Freud offers is 80 teeth but has a special grind that reduces the heat to the equivalent of a 40 tooth.
Charles M
Freud America, Inc.
Ken Oakley-Sunny St. Cloud, Fla.
>I have cut and machined Plexiglas since 1956 and almost always used a triple chip grind carbide blade.For thinner then 1/4" have an 80 tooth one and for thicker I use a 60 tooth one. It can also by cut with a 13 TPI bandsaw blade and scroll saw blades but may chip as it is cut. Carbide routers will also trim Plexi nicely. You can also run the edges across a jointer with good results. I don't reccommend trying to joint plexi on a wide area.It can be run through a planer taking VERY thin amounts on each pass through.
When I purchsed plexi I would whenever possible get cast Plexi as opposed to cast Plexi. The cast does not heat and gum up like the cast will.
Roger
>Ken,
Call me dumb but what is the difference between "cast Plexi as opposed to cast Plexi"?
Roger
>You can call me dumb because even though I previewed the message 3 times to correct mistakes I missed that one .The two types are Cast and Extruded. The cast works much better and doesn't gum up like the extruded.
Yonak
>Also, keep the blade as low as possible to reduce the angle of the cut.
Keith Newton
>David, The finest cross-cut that you have.
Make sure that the sides of the blade are clean if it has cut wood, and of course sharp.
while keeping the blade low, and feeding slow, you can over-do both of those things, and cause melting, and re-weld of the plastic as it comes back around on the blade.
If you have any scrap to practice on, you can figure that out with some sample cuts before you make the final cuts.
If you need really fine cuts, like for gluing up display cases, you will need to set up a router-table, with the infeed set back a little like setting a jointer. For that, I like to use a 5/8 - 3/4" straight cutter. As bits get larger, the cutting angle gets sharper, and the lower angles work better, because it scrapes, and is not as prone to pull out little chips. Here again, feed rate rules.
Mike Harrison
>I've cut quite a bit of sheet acrylic and used both a band saw and table saw. For the band saw a 14 tpi blade works well I bought my first band saw to cut acrylic for a customer, and it paid for itself in less than two weeks.
When you cut on a table saw just feed it like you would 1/4" plywood. Regardless which saw you use, don't feed it slow or it will get hot, melt and you will have a mess on your hands.
I set the table saw blade height like I would if I were cutting plywood. The table saw produces a nicer cut than the band saw.
