ADVERTISE HERE - FREE TRIAL
"Coatings" or whatever on bits and blades...
>So, other than scraping and peeling off the coatings which can be somewhat frustrating for a complex bit - what does everyone else do? It's not so bad with a straight bit, but rail & stile bits or an 80 tooth saw blade? Does someone have a different suggestion? Should I just run some scrap lumber through the saw or router?
Re: "Coatings" or whatever on bits and blades...
Re: use pocketknife to score and peel.
Al Crandall (N.E. of Indy)
Rob Stokes in North Vancouver
>Sometimes I peel it off, sometimes I taker the majority of it off and run a piece of scrap with it to clean the rest of it off. Regardless, I always run a piece of scrap after the coating's been removed to get rid of the residual oils etc.
Rob
