Question about slot mortisers
Denis Ch�nard, Orl�ans, Ont.
>Ignorant one at that...
Are those slot mortisers (of the type seen in combination machines) suitable only for mortising, or can they be used for tenoning too (given the proper cutter)?
DC
Re: Question about slot mortisers
Carol - Strawberry, AZ
>I am not clear about 'combination machines.'
But.
If the cutter is a router bit and the adjustment allows the bit to go below the surface of the table so the cut is taken from the bottom side, the wood flipped and the pass repeated, yes. If there is a x-y sliding table (with clamps for the wood) operated with a 'joy stick,' even better.
You don't want a situation where the wood would be trapped between the cutter and the table!
And I would change the cutter to a spiral cutter, probably a 2 flute end mill (which are available in longer lengths than router bits), to achieve a shearing cut rather than a scraping cut. That also clears the debris from cut faster and allows cooler running (cutter stays sharper longer) and less demand on the motor (also contributing to cooler running).
That help?
Not very efficiently
>You can cut the tenon cheeks okay, but it isn't easy to rout the ends.
Some dedicated machines have templates or adjustable stops that guide the router in a definite path to cut various shapes including tenons, but a typical combo=machine mortiser doesn't have such attachments.
Rick L
Re: Trying to do the tenon...
Rick L
>defeats the whole point of the slot mortiser in my opinion and 25 years of using them. Loose tenons are so much faster and simpler. 2 flute HSS endmills are the preferred tooling. I'll take the slot mortiser over a Domino anyday unless I worked in the field.
Mark Harrison - Brisbane, Australia
>You would have to use different bits. The typical birds mouth slot mortise bit would not be suitable. Probably up cut router bits as somebody else suggested.
However, if you are buying a five function combo, you have a shaper. I would do the tenoning there and either round over the tenons or square up the mortise with a chisel.
John Renzetti
>hi Denis, The slot mortiser attachments found on the combo machines and also the stand alone horizontal boring machines are primarily used to cut an oval shaped mortise in the workpiece. Then a floating tenon is inserted for the joinery. Think of the Festool Domino as a portable slot mortiser. You could possibly cut the tenon using the slot mortiser. I've never done it as the shaper is much quicker and can cut both shoulders at once. I have found that for cutting a square mortise that it is faster to cut the oval and then square off the corners with a cornering chisel than to use the square chisel attachment on my machine.
Some router based units such as the multi-router can be set up to cut the tenons and from what I understand they do this very efficiently.
If you are looking to get a combo jointer/planer get the mortising attachment. It's worth the extra money.
take care,
John
