Air compressor trouble
Denis Ch�nard, Orl�ans, Ont.
>I was in the garage tonight, using an air grinder (the type used apparently in muffler shops, looks like a die grinder, but has a shroud, and uses 3" disks). Ran it a bit hard, i.e. did not let the compressor cycle in and out at times, but then not for that long. I had noticed in the past that when the compressor cycled out I could hear a hissing sound that seemed to come from the pressure switch area, and would last something like 10 seconds or so.
In any case, as I was using the grinder, at some point the compressor stopped kind of unexpectedly. I then heard a "pshttt pshttt pshttt" sound that came from the crankase dipstick vent hole, that lasted maybe 20 seconds. The motor was warm enough that I would not leave my hand on it, but it wasn't that bad...
At first I tought that the "compressor engine" seized, tripping the fuses, but with the power off I could turn the pulley at the motor without much effort. I then guessed that the motor overheated, so I let it rest for an hour or so, pressed the thermal protection button, and tried to restart it. No go. I had checked the fuses before that, and I still get continuity when tested with an ohmmeter.
So it seems that the pressure switch is the culprit, but how can I know for sure? The compressor is a Campbell-Hausfeld, 60 gallon vertical tank, "7 HP" (yeah right), draws 17.5 amps on 220, 15.6/13.7 CFM at 40/90 PSI, cut-in at 110 PSI and cut-off at 135. When it stopped it had not reached 135 PSI, it was about at 125. The compressor is about 8 years old, and has not seen much use. Oil level in the crankcase is OK.
Am I on the right track, or am I missing something?
TIA,
DC
