Much delayed panel saw-long
Ron Hildreth, Alta, Iowa
>Some time ago I posted a message about wanting to install a panel saw in my garage, as taking full sheets of plywood, not to mention heavy melimine, down into my cramped basement shop was getting hard to do for this old body of mine. Someone replied to my post, wanting me to keep them updated, so thought I'd comply.
This panel saw is the kit sold by Rockler for around $284 bucks including shipping. At first I was skeptical of it, but once it arrived, I was impressed with the strength and design of it! There was no hidden problems anywhere as long as your finicky about keeping things absolutely square. All of the plans were concise, easy to understand, and accurate. I built the frame from birch solid veneer core 3/4" ply, and trimmed it with walnut to add to the rigidity of the sheet stock. Once everything was glued and screwed together, I gave it a heavy coat of spar varnish to battle the elements in a garage that occasionally has the overhead door left open and/or a car dripping with salt water during the winter.
I had to hold off even buying a saw for a while - bad winter weather meant long hours with the Highway department, a loss of a loved one, and various other unforseen events caused delays. Finally found the time, and although it's still a project in progress, I've only a few more trivial things to do before having it up and functional.
As you can see by the photo, I still have to get it mounted to the wall, and then double check the squareness of everything before finally mounting the circular saw. I decided to wait until last to mount the saw, knowing that since it will sit on an old concrete floor, I might have to shim it into level. Concrete floors are never perfect. The reason for this decision is to be able to use a plumb-bob as a constant reference should I ever need to make adjustments as the saw carriage wears- gravity never changes!
Behind my new saw is three sheets of melimine, two sheets of 1/2" oak veneered ply and some peg board, all waiting their turn through the saw once running. Just wish I knew what to do with all the junk stacked behind the sheet stock!!
Re: Much delayed panel saw-long
Very Cool - Keep us informed
Chet Kloss from Livonia, MI
>Many of us have thought about building this kit. We'd love to hear how well it works.
,,,,,,,,,,,,Chet
Nice looking gloat there Ron.......
Scott in Eastern Iowa
>....the wallynut sets it off alright......nice!
I'd love to have one, just cant justify it.
Thanks for posting...
Scott
Brian Philipp
>Ron,
Your my hero. I really want a panel saw for my basement wood shop and have finally realized I will never be able to afford a factory made one worth a darn. Keep us informed of how she works after you get/mount a saw ! You have me motivated !!
Al Stokka - Cambridge, Iowa
>"I gave it a heavy coat of spar varnish to battle the elements in a garage that occasionally has the overhead door left open and/or a car dripping with salt water during the winter."
Ron,
Nice work.
I encourage you to shield the aluminum if a vehicle will be anywhere near the panel saw in the winter. Perhaps a cheal sheet of polyethelene. Road salt dropping from the underside of a vehicle will splash a considerable distance and salt likes to eat metal. DAMHIKT!
Al
