conference table touch up
Jim in Fenton, MI
>We have a rather larger maple table in a conference room here at work. It�s natural color with wide maple edges. My assumption is that the top is veneer with a lacquer finish.
Yesterday, someone put a hot pizza on the table and it�s raised the grain in a spot less than 12� with no fogging of the finish or any discoloration. The issue is simply the rough texture.
I�ve been asked if I could take care of it and it looks pretty straight forward. My plan is to smooth the area with 320 or 400 wet-dry, brush it off well and do a coat with spray lacquer from a can.
Does anyone see any issues with this approach? Not sure if I�ll need to do more than one coat of lacquer or how the surface will feel after it dries.
Any tips would be appreciated. Thanks�
Re: conference table touch up
Stephen in Utah
>A friend had the same problem, well ok it was the identical problem, hot pizza raised the grain on a conference table. He was going to do the same thing you did and asked me what I thought.
I told him to make a correct size disk of non-compressible material (he used mdf) and press the spot down. It worked but he did have a 12 ton press to do the job. It just pushed everything back down to the original surface, the finish in tact.
Good luck!
Stephen
