Re: Few comments
Larry Clinton At Frankfort (Central)., Indiana
>First, one blown diode in an alternator circuit will just reduce the output - battery will gradually go down if you are running lights and other heavy load accessories. I can't see how it could affect the operation of the vehicle unless and until the battery was below 12 Volts - When the voltage dropped low enough to prevent proper spark ignition (or computer operation of spark and / or fuel injection if so equipped) vehicle would die and there would be no battery charge to start it. Second, I have changed the "Diode plate" on at least one GM car. It is somewhat of a hassle, you have to dissemble the alternator, replace the plate, insert a couple of paper clips to hold the brushes back, replace the end cap & bolts and remove the clips. However unless the car in question has an expensive alternator, it isn't worth the hassle. My son & I just replaced his last month on a Chevy full size van, I think the cost would have been around $50 ~ $65 bucks EXCEPT - he had replaced it a couple years ago and it had a full lifetime warranty. Replacing the diode plate would not give you the warranty and likely would cost at least half as much as a rebuilt unit. Not sure of what Mazda pickup he has - or the cost of the alternator. It is not extremely hard to change the diode packs and if the alternator is costly probably will be worth the work. HOWEVER - I don't think that will solve your son's problem. May be a clogged fuel filter etc. - lots of things will cause a car to not run properly - but an alternator would be one of the last things I would look at, if the battery is not running down, I would leave the alternator alone.
