What fluorescent lamp to darken cherry?
Hoa Dinh in Alameda
>What kind of fluorescent lamp can I use to speed up the darkening of cherry, instead of putting cherry in the sun?
Thank,
-- Hoa
Re: What fluorescent lamp to darken cherry?
Grant Smith
>I suppose you could use the daylight bulbs, usually labeled as 6000 degrees Kelvin. These are about $5 each for a 4' T-12. I use them in my shop because they make much better photos.
Not sure how effective they'd be in relation to sunlight for darkening Cherry, however.
FWIW,
Grant in Iowa
ReptiGlo Lizard bulbs *LINK*
>I'm assuming it's the UltraViolet light that causes the reaction in the wood.
We buy special high output UVA / UVB bulbs for our lizard tank.
They come in several different "strengths" based on the type of lizards (lower for forest lizards, highest for desert lizards).
Happy Woodworking!
http://www.petsolutions.com/Repti+Glo+8+0+Desert+F
Leappin' Lizzards!
Full Spectrum
Stephen in Utah
Howard Acheson
>First, I don't believe that darkening cherry will go any faster with flourescent lamps. UV is what darkens the wood and I am not sure that flourescent lamps emit as much UV as sunlight. Many flourescent lamps specifically filter out UV so that they do not cause fabrics and woods to fade with they are used indoors.
C'mon, Orphan Annie.
Don Henthorn
Black lights and tanning booths
Michael Dresdner
>Howard is right. While fluorescent lamps do emit some UV, it is a relatively small amount. Black lights, used for DayGlo posters emit more, as do tanning lamps. However, the strongest source are the bulbs used for UV cured finishes. If you know someone who runs a UV finishing line, ask to run your parts through a few times. Otherwise, cozy up to someone who runs a tanning studio.
Larry Clinton At Frankfort (Central)., Indiana
>Hoa, I have purchased and used several UV curing ovens and small chambers prior to my retirement. If you can't find a local source as Michael has suggested, it would be cheaper for you to build a greenhouse type structure and use the sun. UV curing systems are EXPENSIVE, I purchased a small unit - the size of a mini microwave, at a cost of well over $1,000 (don't remember the exact cost - but I had to complete a capital equipment appropriation request to obtain funding). I also purchased a "plate burner" with high uv output bulbs (meant to cure UV curable coatings on printing plates). This was around $2M. I had one curing line with conveyor (12" wide belt - about 8' long) cost was around $25M. Anything I can think of that would provide "1 sun" (common measurement comparing the units UV output to the amount provided by the sun using specific parameters) to an area large enough to cover a small chest or chair would cost in excess of $5,000. Makes the sun pretty convenient, doesn't it!
in_parrothead
>Hoa, you could try an atinic bulb that is used in reef aquariums. They output in the 400nm range and produce that same UV as the sun does, although in a much lesser amount.
Mike
Howard Acheson
>Hoa, why can't you just put them outside? I know that Alameda gets little sun in the summer but there are some sunny days in the winter.
I'm out there frequently as my son and granddaughter live in Berkeley and my son races sailboats out of Alameda. Almost every time I'm out there, I go to Japan Woodworker to see if they have anything new.
I'm serious about using the real sun. I do it frequently here in coastal North Carolina.
OK, OK, Brother Sun then!
Hoa Dinh in Alameda
>I am working on a dresser. The false drawer fronts are cherry, the rest of the dresser is maple. The other night after sanding the drawer fronts, I had them on temporary workbenches, ready for finishing (wipe-on General Finishes oil & vanish). Then I thought about fluorescent lamps to darken them, I could leave the lamps on day and night.
I don't want to leave them in the sun because of the birds that frequent my backyard (you know where birds of the same feather flock together, right?).
It looks like NOT using the sun is more trouble. I'll take my chance with the birds this weekend.
Thanks for the help.
-- Hoa
Richard Klein
>I caution the use of the UV lamps customarily used in the reptile enclosures for this purpose. UV-A and especially the shorter wavelength, higher energy UV-B wavelengths are potentially harmful, especially to the eyes. When they are used in the reptile enclosures, one has the benefit of the glass walls in the enclosure to screen some of the damaging rays. If the lamps are hung "open" in the room, this would not be the case. These wavelengths can damage the retina and do contribute to cataract formation. If you still decide that you must use these lamps, I strongly recommend that you purchase a very good pair of UV-excluding sunglasses. I also remind you that, even though it is a cloudy day at the beach, you can still get a wopper of a sunburn. Why? UV rays. You do not need "sunshine" to get UV radiation. I strongly recommend daylight, with or without "sunlight", rather than artificial UV lamp irradiation, to darken your cherry. Also, more people will get to see your woodworking prowess that way.
