Shellac Happens
Stephen in Utah
>and as it were I am looking for the chemical formula for shellac. Does anyone know what it is?
Stephen
Shellac Happens
Stephen in Utah
Stephen
Re: Shellac Happens
John Parker
>Shellac does not have a formula, It is a natural product produced from the Lac bug.
Re: Shellac Happens
Stephen in Utah
>John,
I know it is a natural product, the exudation of Lacca lucifera, bug poop, but it actually has a chemical formula, quite complex. I had a copy of it years ago but can not seem to find it. As I recall it has more than 12 chemical elements.
Stephen
Not Po
>Stephen,
Shellac is, actually, not poop, but rather a natural secretion of the female "lac-bug" that allows her to stick to the tree trunk of her choice. It is a complex polymer, but can't help you with the actual chemical composition. Try Wikipedia? They might have the chemical makeup or a link to one. Other source might be Michael Dresdner on this board or Jeff Jewitt at Homestead.
mm
A rose by any other name
Stephen in Utah
Hmm, I Must Remember
>NOT to ask you to hand me the glue bottle if you visit my shop!
Shellac formula
Michael Dresdner
>You understand, of course, that shellac contains many elements, including wax, resin, at least two different categories of dyes in a variety of colors. Each dye type and color has a different formulation, as does the wax and other extractives. That said, what I suspect you want is the basic formula for the most common resins.
Shellac resin consists of a number of polyhydroxy acids, mostly aliphatic, varying in molecular weight from 300 to 3000. However, we usually talk about an average molecule represented by
C-60 H-90 O-15
as the basic shellac resin. I'm sorry I do not know how to represent that in correct chemical notation using this word processing program, but I am sure you get the picture. The numbers should be subscripts to the Carbon, Hydrogen, and Oxygen indicators.
Is this what you needed? If not, email me.
Giving females too much credit
Michael Dresdner
>Mark posted: "Shellac is a natural secretion of the female "lac-bug" that allows her to stick to the tree trunk of her choice."
You are giving females too much credit. Shellac is indeed a natural secretion but both males and females secrete it and use it not only to stick to the tree, but as a protective shell similar to a cocoon. On the other hand, the females alone appear to contribute the various dyes that cause shellac to be available in a wide range of colors.
It is also worth noting that shellac resin is collected after the males break out of the cocoon and fly away. The females can not fly. You can fill in the rest of the story, I am sure.
Figures
>The guys get to fly around all over the place while leaving the gals "stuck" at home with the kids.
mm
