I am pretty new to woodworking and was wondering if I could get some help.
I noticed that one of my kitchen cabinet doors is twisted. If I closed the door on the faceframe, ine edge is twistd a whole quarter (1/4") inch. It's a rail and style panel dooe made of maple (I think). It's finished with something. I don;t know what was use. I bought the house with a finished kitchen. ;)
Is there any way I can straighten or flatten it?
I've got clamps. Can I just lay it on a flat surface and clamp down all 4 corners? Will that work or will it just spring back.
I would try adjusting the hinges so that the frame lay flat against the opening. You may have to shim a bit and perhaops even re-drill the screw holes, depending on the configuration of the door.
I forgot to mention that the twist is on the side of the door pull.
So if I shim one of the hinges and or redrill the holes, this one corner will be 1/4" proud of the rest of the doors, which may not be too asthetically pleasing.
Is there a way I can take a part the frame and or reglue them as straight?
>You may be able to "split the difference" with the shimming. Try an 1/8" or less shim under the "opposite" hinge and see if that helps enough that you can ignore the problem. Remember that once you have seen this it appears horrible to you and others my not notice it at all.
To answer your question, you most probably can not clamp the door to a flat surface and correct it. Even if you clamp it past flat in the opposite direction and leave it a while (days or weeks) it is unlikely it will stay flat after you remove the clamps.
As far as taking the door apart, I would not count on doing that and being able to reassemble the door. It may be pinned or stapled on the back side in addition to being glued. The concept here is to make very strong doors so they don't fall apart, thus they don't come apart easily. It is conceivable you could heat the joints and take them apart, but pretty unlikely.
Try laying a straight edge across the door to see if you can see what happened. Was the door like this all along and you just finally noticed, or did it warp? The straight edge may reveal that one or more of the stiles or rails has warped or that some of the joints were twisted or that the panel has expanded and warped the door. Figuring out exactly what the problem is may lead to an answer.
There was a recent short thread on this topic and another one within the past year or so. As I remember it, there isn't a very satisfactory solution for this problem - especially for a door with a 1/4 inch gap. Switching to a European-style hinge would allow you to more easily adjust the door and to "balance" the gap top and bottom. Doing this would require that your current stile be wide enough (roughly 2 1/2 inches) to accommodate the hole needed for the Euro hinge, plus having to buy a forstner bit, plus having a drill press (or a steady hand with a hand drill) etc. etc. But it might be worth it to keep the same style door and finish in your kitchen. You also might need a couple of rubber bumpers on the backside of the door to minimize the vibration of the door when it slams shut. Just some thoughts.
I think the cabinet door was slightly twisted when I bought the house. It could have twisted more over the 4 years I have been living here. I didn't know it was that bad (or at least I didn't notice) until recently. Mabe as I get more into woodworking, I see things with different eyes. Look more closely at each piece of wooden furniture ;)
Will see if I can shim it. If not I may have to duplicate the door and stain to match the existing doors. Wish me luck ;)
Before replicating the door see how little of the face frame corner remains proud. I happened to notice a cabinet I made in 1963 and restored 4 years ago. The new raised panel doors were significantly warped that they required clever shimming and hinge gaining. Alas, they still were not good enough. I closed them and used a scribe to define how proud they were, and where. Then I used my block plane on the face of the stiles and rails to make them flatten out. They were ribbon mahogany and looked beautiful. I didn't want to ruin them, or have to replace them. The block plane worked very well. Now the doors are flat, flat when closed, and only a little skinnier in places. Once finished, you can't tell. Shhhh! I won't tell either.
