walker turner band saw
Dave Endres
>I recently purchased an older Walker Turner bandsaw. Serial No. 11356390 with 16" wheels. Anyone know where I can buy a few parts? I have one cracked casting on housing 4 table leveler. May need new tires. Dave
Dave Endres
owwm *LINK*
Tom Sontag - St. Louis
>The folks at owwm.com are for you and your situation.
Old WW'g Machines site
Believe it or not...
>...at one point Delta bought all that was left of Walker-Turner, including parts. I recall learning that during a tour of their old Memphis distribution center years ago. (Course, my memory isn't what it used to be. :-) You might try calling Delta to see if they can help.
I had a W-T 16" wood cutting bandsaw in my old shop, but I chucked the remains of it after the fire. Too bad. There were probably some salvageable parts on it.
Ellis Walentine, Host
Re: walker turner band saw
John in New Mexico
>I've got one of those in Tucson. Mine is the type that you can put a gearbox on-- if you can find one-- and run at really low speed for cutting steel. If I ever go get it, I'm planning to get an old 3 phase motor and VFD to do the same :)
Heaviest 16" bandsaw I ever moved.
John
Re: Believe it or not...
john jesseph
>I think John Weber bought out a lot of the old Delta parts stock. IIRC he got semi loads of randomly packed stuff, maybe he got the WT stuff. You could try e-mailing him...sales@weberwoodworking.com If I can find it I'll post the link to another WT supplier, can't think of it now...sorry everyone to waste the bandwidth on non hand tool stuff...
Hank Knight in SC
>Dave,
Turner Serviced Machinery, LLC is a small company in Connecticut that specializes in rebuilding Walker Turner machines. They sell parts. Jeff Hoffman is the owner (I think), or the head guy there. He's very nice and has an encyclopedic knowledge of Walker Turner machines. Jeff helped me through rebuilding a very beat-up WT drill press that had lots of problems, and he had parts I couldn't find anywhere else. Among other things, he rebuilt the original motor and it looks and runs like a brand new one. Drop him an e-mail at wtsmllc@juno.com and see if he can help you find what you need.
Hank
Oops!
Hank Knight in SC
>That should be "Walker Turner Serviced Machinery, LLC."
Mine has the gearbox.
>Between the 2-speed-range gearbox and a 4-shiv pulley, I think I have about 16 speeds on this 16" Walker Turner of mine. Actually, for wood, I never change the speed. I liked my old WT16" better because it had an 11" resaw depth. The metal-cutting model only has 8".
Frank Klausz did a tricky modification on his 16" WT: He took off the top of the saw and bolted it back on two inches higher to gain resaw capacity. Been meaning to try that, but now with my 20" saw, I don't need to "fix" the WT anymore. :-)
Cheers,
Wow! Great ref. Thanks!
Yep, mine only has 8" cut height...
John in New Mexico
>But doing occassional steelwork, its really handy for cutting up 10 gauge parts. A friend and I found a speed reduction box when I first got it that got it down to a good speed for steel. Works ok but kinda ugly - we had to shim out the motor cover an inch or so to accomodate the extra bits. I've got one of those tall Generals for general use and the small bit of re-sawing that I end up doing.
John
