Router combo kits
Router combo kits
Router combo kits
Johnny
>Yesterday I was in Lowes looking at router combo kits. The Porter-Cable router that I have works great(It's a 690), but it does'nt have electronic variable speed. Not only that but I'm in the market for a plunge router and these Combo kits just seem like the ticket. After looking them over, After examining the Hitachi,Makita, Dewalt, Bosch and Porter-Cable,I sort of narrowed it down to the Bosh and the Porter-Cable. In examining the Bosch fixed base, I found it very hard in trying to raise the motor even though the 'hold-down' clamp was open. Was I doing something wrong?
The Porter-Cable plunge base was heavier, and the fixed base had a better 'raising and lowering' system than any of the others, and both bases just seemed to be better made than any of the rest. Could I get some input please from those who have used these new machines. I'm sure that they're all very good, but I'd like to know which one you think is the best. Thanks.
Re: Router combo kits
frank shic
>if you're talking about the bosch 1617, make sure that the router casing is SHINY and not corroded as some of the earlier models like mine were. after i sent it back to the factory to be replaced, it worked just fine. next time you're at home depot, you should also check out the ridgid combo. it has a clear base and uses porter cable templates and it includes a centering cone and all the dust attachments.
A Lot To Pay For The Wrong Base(s)
>Good Afternoon Johnny,
I don't want to start a war: I actually have all the bases for the P+C 690 system. I didn't buy them in a kit, but individually. I find that I hardly ever/almost never use the plunge base. The standard base is just okay to my mind. They are the two bases most commonly available in kit form for around $200. If you use BOTH of them regularly, its a nice deal. However, I use my D-Handle base nearly exclusively when I take the router out of the table. I just bought another P+C 690 used, which came with a standard base. I am seeking another D Handled base for its motor and will get rid of one or more of my standard bases when I pick up a used D Handle. I could also be talked out of my P+C plunge base pretty easily.
George
George
DW618 3-Base Kit *LINK*
Hoa Dinh in Alameda
>I'm surprised you didn't mention DW618 combo.
If you think you use the plunge base much, don't buy the PC690. Over the years I bought several PC690 kits, but always sold the plunge base. I finally moved away from the PC690 altogether for the DW618. The plunge base in particular has built-in dust collection, a must for my shelf hole jig.
The 3-base kit does not cost much more than the 2-base kit, especially if you find a promo/special deal from Amazon. My local HD has the 3-base kit that includes an edge guide for $279.
-- Hoa
My DW618 Kit
Jim Moore
>Hi Johhny. I have two PC 690 kits and all of the bases. I am the opposite of Col George. I have only used the D base once. I use the standard fixed-base the most. I have lots of routers so each one typically has a dedicated use. For instance, I use the PC 690 with a fixed based exclusively on the Leigh jig. I use a 690 with the plunge base when using it on my Joint-a-Bility to edge-plane boards before I glue them up into panels. I have no complaints regarding the combo kits. The last one I bought came with a free D-handle. I would recommend the kit.
While waiting...
Hoa Dinh in Alameda
>for a real D-handle base, how about a poor man's version of it?
-- Hoa
Nice Job Hoa
>Good Afternoon Hoa,
What I really like about the PC D-Handle base is the trigger location, but I admit I do like yours very much. Where did you get the clear base, and was it tapped? I can make the handle without much fuss. Maybe I can build yours and wait a while. Nice job. BTW, what was your choice of wood?
George
Poor Man's D-Handle Base
Hoa Dinh in Alameda
>Hi George,
I actually used the base for quite some time before getting a free D-handle base from a PC promotion deal.
I made the subbase (as many others in my subbase collection) from clear plastics from the scrap bin of my local plastics store (TAP Plastics). They recently raised the price from $2/lb to $3/lb. But I'd bought enough for the rest of my life. If you don't have a local plastics store nearby, I can drop a few pieces in the mail to you.
The handle is patterned after the tote of my #4 Bailey. The wood is sugar maple, finished with boiled linseed oil.
-- Hoa
Sent you an email, Hoa. Thanks
This DW618 3-Base Kit will be on sale next month
Art Silva
>at Woodcraft for $300., and a $50.00 mail-in rebate direct from DeWalt, for net of $250. before any taxes. I have had this kit since it came out, and I find its features put it way ahead of all others.
Johnny
>Thanks for the tip, Frank, especially about the dust part. Of all the ones I seen at Lowes, the only one that I could see that had anything to do with dust controll was the Dewalt. I was a little disappointed that the others did'nt have it. I think I'll take a ride over to Home Depot this afternoon and check out the Rigid. Thanks again.
Johnny
>Thanks for your input, Jim.
