walnut
walnut
walnut
bhenr99
>I need to darken some walnut. Never stained walnut before. What would a good way to darken it? Thanks for any help.
Bob
Re: walnut
Re: walnut
>Maybe Russ or somebody who really knows what they are talking about will chime in here, but here goes anyway.
First, you can stain or die walnut just like any other wood. I think many people stain it even thought it is already brown, to even out he color and to help it resist turning lighter and sort of reddish over the years.
Also, you can "ebonize" walnut (and other woods). Mix or soak some (real) steel wood in vinegar for several days. Apply the liquid to the walnut and watch what happens. It will darken and if you get the mixture strong enough, turn it nearly black. May take some experimentation to get the results you want. You also need to apply some finish to the test samples to see what it will really look like. The process does not go deeply into the wood, so you cannot sand it (much) after you ebonize it. Some people seem to find it easier to use India ink.
Give us more details about what and why and maybe we can help more.
Re: walnut
Re: walnut
Tony - Memphis
>Something I have tried recently is Vandyke crystals - stain made from walnut shells. I was turned onto it as a way to match the sapwood. I got mine from Lockwood. I'm sure any of the water based dyes would be a good choice too.
Tony
Re: walnut
Re: walnut
bhenr99
>What I have is a piece made out of figured walnut and want it to sit on a base. Problem I can't use the same figured walnut for base as it is to small in diameter. I have to use another piece of walnut and it has to be darkened to match the piece as close as possible.
Bob
Re: walnut
Re: walnut
Dave Bair, Eaton Rapids, MI
>Walnut can be fumed with ammonia, using the same process for fuming white oak.
Re: walnut
Re: suggestion...
Glenn Madsen near San Francisco
>Rather than go for match, go for accent or flow. The color of walnut, stained or not, will change, particularly from two trees. Might as well start with something that looks like it was supposed to differ, and then let the pieces change as they will.
Certain things, we cannot completely control.
