Aligning Delta Tennon jig.
>I have a Delta Tennon jig that is apparently out of alignment. (I checked the TS and it is good, so the slot is parallel to the blade.) When I try to cut a cheek on a tennon it is as if the jig is at an angle to the blade. (It is �turned� in the same way you turn your miter guage.) I cut one side, flipped it and cut the other. The tennon is angled about two or three hundredths.
I thought it would be a matter of loosening the screws holding the bar that slides in the groove on the table and twisting the entire gig until it was parallel to the blade, but the bolts come into the bar from inside the jig. Now it appears I would have to completely disassemble the jig? This does not make sense. How can I line up something that is in pieces? Can somebody clue me in?
Re: Aligning Delta Tennon jig.
Never Mind! I figured it out....
>Went back to get the model number so I could look it up on the Delta site and noticed the holes in the base plate. Moving the plate all the way to the right lets you get to two allen screws. Loosen, adjust, tighten, go back to work. Thanks anyway. When it works it work great.
albertabob
>If I had just one guess, I would think you have a dud on your hands.
That operation should have been checked at the factory and it sounds like the holes were drilled in the wrong spots on the casting.
A machine shop can align it but it might be costly.
Bob
