Interesting tablesaw incident last night
Pete in Holland, MI
>While ripping up a bunch of 3/4" oak for a project, my 10 year old JET 10" contractor saw supprised me. Part way thru a rip, it starting vibrating something terrible. Upon analysis of what was wrong, I found the v-belt pulley on the saw arbor had split and lost half of a sidewall.
I have been running one of the segmented belts for a couple years, and also have about a 5# weight hanging on the motor to give the belt more tension. The 1-1/2 hp motor was also rewired for 220v years ago.
Am off to the v-belt pulley store this morning to get a replacement, only this time, the new pulley will be steel or cast iron. Will replace the one on the motor at the same time too.
Wierd........
Re: Interesting tablesaw incident last night
Pat Schupbach
>Check Woodcraft, I think they carry a kit with machined pulleys. Might work with pals alignment kit. Glad you were not hurt.
Let Jet know.....
>If Jet discovers that there are a few people who experience this, it might save someone from injury later.
Glad it didn't cause anything serious.
Happy Woodworking!
I had the same thing happen.
Keith Newton
>last year on my little 9" rockwell saw that I take to job-sites after 30 years.
arw01
>I had plans to replace my arbor pulley a couple of years ago when replacing the arbor bearings. However, the arbor was of non standard diameter and had to replace with another Jet pulley.
Their shipping fees at WMH are outrageous, so I had a co-worker stop at their warehouse to pick it up. I was STILL charged a $5.00 handlng fee!
Alan
About the 5 lb weight..
Bri in Mtl
>Won't jet be asking what was the thinking behind hanging a 5 pound weight on the motor?
Actually, I'm wondering the same thing..
Pulley
Bill Howatt
>If the pulley in question is one of the "cast pot metal" types found on many devices, this is a typical failure mode. I've seen it on furnace fan motors several times.
Bill
They will......
>Good point.
I have no doubt that Jet will place a very large 18" x 10" bright yellow sticker on all future tablesaws they sell that says:
Danger, do not hang 5lb weight from motor mount!
Serious injury, death or dimemberment may occur
And they will stick this sticker on the motor in such a way that you can't install it without removing the sticker.
Happy Woodworking!
Re: About the 5 lb weight..
Pete LaBelle
>I have experienced problems with belt slippage on heavy ripping in the past. This way it allows me to use all of the horsepower of the machine.
New parts on the way ! !
Pete LaBelle
>Contacted my local Woodcraft dealer. He's ordered me up a pair of machined steel pulleys (as a up-grade option for these saws). $30 delivered to my door. Should be here in a couple days. Seems the better more expensive saws have steel pulleys on them, so that must be a sign against the cheaper-to-make aluminum or zinc pulleys.
Note that the arbor pulley is a metric shaft size and metric bore pulleys are not too easy to find.
I have read a couple of your responses regarding the weight on my motor. The weight is there to increase the belt tension, as the motor by itself isn't enough. It is actually a half gallon of old glue hung from a string years ago when I was doing some ripping and the belt kept slipping. If the belt slips under a load, without even slowing the motor, it indicates that either the belt is too loose or the motor is too big. This way, I can use all of the 1.5hp that the saw is supposed to deliver.
Thanks for your concern, guys.
Re: Another cause of low power transmission...
Al Stokka - Cambridge, Iowa
>"If the belt slips under a load, without even slowing the motor, it indicates that either the belt is too loose or the motor is too big."
Another cause is a glazed belt. Particularly if it is a wrapped belt (as opposed to a raw edge belt).
Al
Pat Schupbach
>Another good upgrade is a link belt. I put one on my Jet saw, what a difference!!
Pete LaBelle
>Have had a link belt for a couple years! Replaced the OEM wrapped belt with a cut belt at some point and that slipped less than the wrapped belt, thus was a step above.
