router dust collection
mike mcnerney
>Has anybody seen or got a link on router dust collection in a hand held application, not table mount. I'll be using the Milwaukee 3.5 hp with a rub collar.
Mike McNerney in Ottawa
mike mcnerney
Re: router dust collection
frank shic
>porter cable's got a dust collection system for their smaller and larger routers. perhaps you could adapt it for the milwaukee router base.
Mike - Will You Be....
Howard In Toronto
>.... edge-routing or routing in the middle of your material?
If you're edge-routing, as mentioned above, P-C makes a below-the-base attatchment.
I feel it works fairly well.
They make it for their own products but it'll fit other brands that based their base and screw patterns on the P-C - like my Makita 11-series routers.
Perhaps you can check your Milwaukee against P-C products to see if it'll fit or take a mod.
As far as routing in the middle of a board, my Makitas have a little plastic "thing" that surrounds the bit and leads to a shop vac hose.
It works okay.
Perhaps you can check Milwaukee's website for accessories or do a mod on the Makita item too.
HTH
Howard
