Large Cherry Tree
Large Cherry Tree
Large Cherry Tree
Ralph Gillwald
>A large straight cherry recently uprooted and fell on my property.
The limbs have been removed but the majority of the truck remains.
I don't have any measurements right now but it is probable at least 40 feet long with a diameter of 2 feet maybe more.
I live in VA.
Is it worth anything and who could I contact for harvesting?
Re: Large Cherry Tree
Here is a good place to start looking
Keith Newton
>for a sawyer. Just scroll down to your state, and see if you can find someone near you with a portable mill.
http://www.woodweb.com/Resources/RSSDGsawyers.html
value
Tom Sontag - St. Louis
>Dry cherry lumber of course has value, but your situation is several steps removed from that. Not much time needs to lapse before you will realize that you really have an asset (it's cherry) that may or may not offset your liability (you have a large heavy object on your lawn).
As mentioned, your best shot at breaking even or maybe even a small amount better is to contact a portable bandsaw owner who is accustomed to dealing with one-off situations like this. Calling the 800 number for Woodmizer and Timber King will yield names near your zip code.
Matt Berry
>Yes, cherry is great to work with and is worth a little bit of money. Contact sawyers in your area. Your best bet would be to go to the woodmizer or timberking websites, I believe if you contact them they have numbers of local people in your area. Other options are peterson swing mills or something similar.
If you know somebody with a lathe, there is a treasure trove of lathe blanks in there, you just need a chainsaw and some anchorseal.
Curly Smith
>This is a very useful site for forestry and timber questions:
Forestry publications
In particular, this article
How to Measure Trees and Logs
will tell you how much wood you actually have.
Sorry to tell you but your tree has no value. There's simply not enough wood from a single tree to justify somebody buying it from you. There's not even enough wood to justify trading the wood from the labor.
Your best bet would be to post on the turning board, contract the local turning group, or ask a local arborist who they give their wood to. I'd be happy to take your wood but it's a bit too far to drive.
>I think the others that told you that the tree is of little value are correct. Too many variables. Is it easy to get to? Is it sound? How long has it been down? Etc. There is also some liability in just letting someone cut it up.
Having said that, It would gaul me to not do something with it. It would be nice to do something good with it and turn it into something beautiful.
You might try posting this on the turning board (see left). Try looking for Barbara Gill. She has a sawmill down near Urbana and she is a turner. Someone over there might be able to help or maybe Barbara can put you onto somebody.
Where are you? There might be a nearby turning club. There are several in the state.
nailshooter
>One of the biggest things that will keep a sawyer from being interested in a suburban tree of any size is the fact so many have pieces of wire fencing, nails, screws, lead bullets(!) and all manner of other things that could have been introduced to it many years ago.
I just got through taking down an oak at a house that was built 30+ years ago. The tree was about 40" in diameter. Inside the tree, about 4 feet off the ground was a piece of hard limestone, which had wound up inside the tree. You can imagine what it did to my chainsaw blade. No telling how long that rock had been in there, and how it got there as the tree had grown completely around it.
If they will touch an urban tree, the sawyers around here have a hefty blade deposit in case they find a similar surprise.
Robert
Matt Berry
>I don't know if I'd call it a hefty blade deposit. Most sawyers do tell you up front that for a damaged blade, you bought the blade. The fee usually ranges $25 - $30. A lot of them also carry metal detectors so metal objects are usually caught, concrete, stones, ceramic insulators are not.
Other options besides the turning blanks I said earlier is to rive the wood using splitting wedges, a lot of work, but it can be fun. You can also cut it into cants using a chainsaw and let it air dry that way.
Somewhat Different Experience
>Good Afternoon Ralph,
Saving the opinions expressed elsewhere in this thread as valid, I need to chime in on the cherry trunk from my #2 daughter's hurricane-downed cherry tree. It was about your size. We got a carrier to haul it to and from a band mill. I spotted some metal in the tree before it was felled, and so advised my SIL who located it in one of the trunk sections. They slabbed the tree and gave me the 4/4 planks and bowl blanks from branches. The tree provided my family with numerous pieces of cherry furniture. The pix shows last year's project which gives a whole 'nuther meaning to the phrase "family tree". Its very nice when you can literally use home grown materials to grow your own home. It was well worth the risks.
George
Re: Somewhat Different Experience
nailshooter
>George, I think you have lived every woodworker's dream: low cost wood with a history, wood that can be made into something beautiful and useful.
When it works it is a thing to behold, no doubt.
But then getting it to work...
I know if it was me I would try to get anything possible into boards, then turning blanks, then firewood. Econically, I don't know how the boards would work out, but the turning blanks and bbq/firewood would be a given.
Robert
Hamish
>George, your work is really beautiful, your family must be very proud of you. Many congratulations, Hamish.
Ted Wong
>Some may be correct in saying the tree may not have commercial value. If you are a woodworker or know of a woodworker I'd have to say it most definitely has value. Especially if you can get it milled. As some have mentioned all sorts of oddities can end up in trees grown in peoples yards. On the otherhand I've had at least a dozen yard trees cut up over the years and only one contained metal. It's pretty much a roll of the dice but chances are if the tree isn't rotten at the base and it's straight I'd look into finding someone to cut it up into planks and as a last resort into bowl blanks.
Philip Duffy
>Ralph, I sent you a personal message/email. Philip
Re: those sawyers don't call back
arw01
>I got that list for here in Eastern Washington last summer. Not a SINGLE one over over 24 people EVER called back.
Even sent letters to three of them.
Alan
