trick for removing great stuff
Steve Silca
>Just installed some windows and filled the perimeter with great stuff. What's the trick for removing the stuff that has expanded and adhered to the window frame? Thinner?
Re: trick for removing great stuff
>Razor blades are the only things I found that worked. My wife got it all over her hands and no solvent we tried would cut it. I didn't use the razor blades on her. I use the blades to cut it and scrape it off the windows.
Keith Newton
>After it has dried, I like to use a filet knife to just cut away the bulges, then use a random orbit sander to remove the residue if it gets on finish surfaces.
If you fool with it while it is wet, you run the risk of deflating / collapsing the part that you want to keep.
Mark Nowicki
>Scraper or putty knife, then acetone.
Mark
P.S. If "just" means today or yesterday, and the windows are Borg plastic, ans if you overfilled the cavity, wait before you finish the inside.
Trick is to use latex instead....
John in New Mexico
>I don't mean to sound snotty, but there's no comparison. You don't even need to use up the whole can if you rinse the nozzle well. Only drawback to it is the cans will go flat after a year or two.
John
Re: Trick is to use latex instead....
Steve Silca
>What are the brand names for a latex expanding foam? Availability?
Steve Silca
>I installed vinyl windows. Will acetone eat into the vinyl?
What do you mean "wait" if I did it yesterday (which I did). How long do I wait?
made by dap...
John in New Mexico
>its just latex caulking in a can with propellent.
I've bought it at Lowes and some hardware stores. Not sure if HD carries it or not. Usually in the same isle as the insulation products, at least at Lowes.
John
Dave Bair, Eaton Rapids, MI
>There are two types of expanding foam: polyurethane and latex. The latex is easy to clean up but is not nearly as rigid (or as good for insulating in MHO) as the poly.
Mark Nowicki
>At least a week.
Seems to me that you overfilled the cavity, otherwise you would not have
the cleanup problem. That foam inside the cavity will remain wet and continue too expand, even though it appears to be dry on the outside. Vinyl windows frames are, to put it politely, not very rigid, so the expansion will squeeze the frame and affect the operation. BTW, which Great Stuff product and applicator did you use?
Mark
Do not use latex...
Mark Nowicki
>Latex will absorb the moisture that passes in and out of the house, especially around window frames. Damp insulation is worse than no insulation at all, unless you want to grow mushrooms in your walls.
Mark
Steve Silca
>Gotcha. I'll give it a few days to completely cure.
I used the blue bottled great stuff for doors and windows and used the the provided nozzle extension.
SS
