A55 Smoothing Plane
"YELLOW Planing woes
j smith
>It seems every time i try to plane yellow pine with my hand planes, that gouging occurs with unsitley results. the plane does well on smoother grain materials including oak. I dont know whether the grind angle is wrong or what. the sappy grain seems to be the most bother some . Any suggestions? thanks, j. smith
Re: "YELLOW Planing woes
Curly Smith
>A plane? Something wrong with the belt sander?
How about:
A Softwood Scraper Mystery
Chipbreaking
from Plane Basics
"The other major factor that causes problems for the novice is the depth of cut and mouth opening relationship. The mouth is opened and closed by adjusting the frog. It�s very important that the shaving is supported as it�s being sliced up and away from the surface. If the mouth is open too much, you will get tear out and chattering not opened enough it the plane will choke. The mouth opening should be just a hair over the amount of the depth of cut. In other words, slightly more than the thickness of the shaving."
Make sure the iron is sharp
>My best advice is to check your plane iron for sharpness. A really sharp blade should slice cleanly through yellow pine, assuming you're pushing with the grain and not against it. Also, take smaller bites with the plane.
Ellis Walentine, Host
