Compost Bin
Compost Bin
Compost Bin
david b
>Anybody have any plans they would care to share,or good tips that I need to consider when making a compost bin?
Thanks,
db
Re: Compost Bin
Re: Compost Bin
Ron in Drums PA
>Nail three pallets (skids) into a U
Fill with organic material.
Repeat if necessary.
Re: Compost Bin
Re: Compost Bin
>Good Evening Dave,
Anything which will contain the decomposing material will work. I took four steel stakes about 5 feet long, drove them into the ground, and wrapped them in chicken wire, leaving one face open near the ground. I removed the compost with a shovel from there. I also used a hoe to turn the soil over once in awile. I used a little garbage now and again, but mostly grass clippings. I never ran out of compost. My tomatoes got so big that I needed a change the zoning requirements from residential to farming.
George
Re: Compost Bin
Re: Compost Bin
Jim Shaver - Oakville, Ontario
>Hi David,
I have been around composters for a long time, my dad had one in the back of our garden when I was a kid, it was all natural with no structure, just layered green materials with alternating brown layers.
12 years ago I bought a commercial plastic composter, layered brown and green layers and bought a box of Compost starter at a Garden centre, it's been running non stop since then. I empty it out from the base about once a year, taking a wheel barrow full, adding a few shovel fulls back into the top and then I mix the entire balance remaining, then layer on about 3 inches of yard waste from the fall and then I put kitchen waste back on top and she's good for anther year.
Hope that helps,
Keep your materials for composting to be organic matter, no meat of bones etc.
Take care,
Jim
Re: Compost Bin
Not an expert...
Denis Ch�nard, Orl�ans, Ont.
>But I wouldn't make one out of wood.
I'm saying that because I've heard stories about rodents and other varmint gnawing their way through the wood to get at what's inside. Maybe it's just old wife's tales, but I'm just not taking any chances, I hate these critters...
I have a plastic one similar to Jim's, and haven't had a problem in the five years I've been living at my current address.
Also, the advice not to put "animal stuff" in the composter is a good one, because then you can attract a whole new bunch of different critters...
DC
Re: Compost Bin
Re: Compost Bin
>I've had several over the years. At one point, I used pieces of fairly sturdy fencing (Dog wire with 1 X 2" holes) about 3' high. The pieces were 12'+/- long and I just formed them into circle or hoops and folded the wires from one end through the other to hold them. Just threw yard waste in and let it sit a while. Too lazy to turn it. When I need some, I just took the wire off the pile and used a fork and wheel barrow to move it into the garden. Now that the wire has rusted and worn out, I just make piles in the edge fo the woods. I dig the good stuff out of the middle and fold in the rest. I used to be really into it and would go up and down the street and collect my neighbors leafs and grass clippings. I was at about 300% recycling.
The one I lusted after was a large was a large plastic drum (4' x4'?) on a horizontal shaft on a rack. You load in the stuff through a trap door and tumble it. After two or three weeks you park your wheel barrow below and open the trap door. They even had a motorized version that tumbled automatically. Just like Americans to motorize a process that occurs naturally a that would occur whether we helped or not.
Now I put my non walnut shavings in the dog's pen to sheet compost and for him to enrich.
Re: Compost Bin
Re: Compost Bin
Ed O'Neill
>Just wanted to add my 2 cents. I built a square foot garden as shown on public television. My wife and I really enjoy gardening and this unique concept. I had composted for years using 2 turkey wire baskets which I put grass clippings and mulched leaves. One year I really loaded up the beds where I planted tomatoes. By the end of the season I had plants that looked like trees 3 inch diameter stalks that reached as high as the eves on my house. Green lush plants but not one damn tomatoe. The lesson to be learned is to not to use too much good rich compost in your garden. Ed
Re: Compost Bin
Compost content
Tom Dunlap in Atlanta
>Keeping animal remains out of garden compost makes good sense. They are more likely to attract vermin than old plant material. A more important issue is sanitation. Typically a home compost pile doesn't get hot enough to kill all of the nasty micro organisms that would grow on old animal castoffs. You could be cooking up a cesspool if you weren't careful.
The compost bin that I had was made from four sections of worn out four foot tall 1x3 redwood picket fencing. The corners were simply screwed together. All greenstuff went in the top. I would put my leaves in the street and run my lawnmower back and forth to shred them down. In the bin and next to the garden. Every once in a while I would shovel in a scoop of soil just to keep the roguish fungiis alive in the compost.
Re: Compost Bin
Re: Compost Bin
NickB
>I have the plastic, kind of modular ones (the town we used to live in sold them at a discount to encourage composting). Works great in terms of keeping things contained and not rotting, but you really need to have two of them if you are going to effectively turn the pile (most easily accomplished by transferring to the second bin and mixing as you go along). We moved 2 1/2 years ago, and I haven't turned this pile yet (3 small kids and lots of other stuff to do). I keep thinking about getting one of the compost rollers (another poster talked about them), but what are the odds that I would actually roller the thing?
Lee Valley sells some steel brackets to make a bin with wood. It'd probably work fine if you used a very rot resistant wood.
BTW, a bin that would keep the critters out would probably not work very well as a composting bin (the compost needs air), but if you keep out the animal products and fats/oils, you ought to limit yourself to whatever rodents are in you yard.
Hope this helps,
Nick
Re: Compost Bin
Bins vs Piles
Curly Smith
>Composting bins and composting piles are distinct composting systems. The bins work better but the piles are much easier. I use welded wire wrapped around trees to support my composting pile but if you want to build a bin:
Constructing Compost Bins
Compost Bin Construction Plans
Compost Bin
Building a Compost Bin
Compost bin plan
and from our friends at Lee Valley:
Composter Bracket Set
Compost Bin & Grow Barrel
Re: Compost Bin
Re: Compost Bin *LINK*
Dick Vitel
>Ditto.....currently have a "W" (2 bins next to each other). Oh and do make your own. Currently I am in the minus column this year for contributing yard waste and saw dust to the landfill. I achive this be getting used coffee grounds from Starbucks as part of their grounds for gardens program. OH MY GOD....starting to sound like Ed Begly Jr...have to go compost myself now!!!
http://www.edbegley.com/
Re: Compost Bin
Hot Compost......
>I looked out one day and saw my compost pile steaming. I had a thermometer with a six inch stem. Stuck it in and got a reading of 140 Degrees (F). Thought "It couldn't be", Stuck my hand in, OUCH!, it was.
I threw in some brown, some green, some dirt and a little fertilizer, and wet it down.
Grew great potatoes one year. In stead of rotting or composting, they grew. Great little white potatoes.
Re: Compost Bin
I've even heard of radiant heating...
John in New Mexico
>with a compost pile as a heat source. They do get very hot if they're big enough.
John
Re: Compost Bin
Re: I've even heard of radiant heating...
Dick Vitel
>My highest record temperature has been 166. I regulary hit 150s to 160s
Re: Compost Bin
my sister's caught on fire
GolfSteve in Calgary
>My sister's compost bin caught on fire, burned down one section of cedar fence, and damaged the side of her house. It caught on fire at night, and the only reason they caught it was that a neighbour heard the crackling sound and thought it might be hailing, so looked out the window. My brother-in-law had smelled smoke as he was going to bed, but thought one of the neighbours must be having a back-yard fire.
When the fire department arrived, they said that compost bins catch on fire all the time here in Calgary due to spontaneous combustion. Apparently my sister should have been keeping the bin a bit more moist and needed to turn it more often.
This bin was a small (say 3' high) plastic job that the city cells.
Anyway, my advice is to not locate the bin near your house.
Re: Compost Bin
Garden Guru Mike McGrath
>Now I know youse guys are all woodworkers (and Ellis says I ain't too bright!), But "Larry Moe Curly" (love that ID, you knucklehead)is right on the money here: Big circular bins made of animal fencing are much less expensive, easier to make, take almost no time and have much better airflow. I have every type of bin and those wire cages last forever (and can do double duty as tamata cages in the summer); the wood bins always rot eventually, no matter how naturally rot-resistant the wood. (Of course, you Brianiacs KNOW not to use any kind of chemically treated wood). You can also do my chimney trick more easily with "Fencing bins". See the link below.
Basic composting with chimney trick
Re: Compost Bin
Fixed double http://
Dan Donaldson
Re: Compost Bin
Great place to cook something that needs long slow
Don Henthorn
>cooking. Similar to the European country people cooking in the straw and manure piles they had beside their front doors.
