Quartrer sawn oak drying - - it's cracking on me !
Pete in Holland, MI
>Guys -
Had 35 quarter sawn white oak full 2x6's sawn up in November, stickered them, and left them to dry some over the winter out in the open. Checked them today and the 2" faces are experiencing a significant amount of checking. The 6" faces are pretty much fine.
Due to the thickness, am I assuming they are drying too fast on the outside? Would this be the nature of quarter sawn 2" white oak during drying ?
Seeking your wisdom........
Pete
Re: Quartrer sawn oak drying - - it's cracking on me !
Scott in Eastern Iowa
>So let me see if I understand this scenario:
The 6" top (face) is ok, but the 2" end is showing slight cracks seen with the checking you refer to ....right?
Did you seal the ends at all?....using Anchorseal, or equiv. product?
If not this would be the norm for any wood....no matter if its QS, rift or flatsawn. Dont expect it to travel too far.....3-12" at the most....though I have had hickory end check 24" before.
Scott
Keith Newton
>You are correct in your assumption. You can put a tarp over your stack for a day or two at a time to slow it down and give the middle some time to catch up with the outside.
You may want to keep an eye on the RH as the weather warms up, and cover it on the driest days especially if it is windy.
Dale Lenz
Dale Lenz
>Pete,
Are the 2" edges getting wet during rain, rewetting wood will cause this. Is it mainly the outside boards with this problem?
Pete LaBelle
>The wood is not available for me to see, but am told it is all along the 2" faces where the checking is going on. I tend to agree that this stuff will need a slower drying period than would inch stuff.
Keep you posted.......
Pete
too fast
Tom Sontag - St. Louis
>Oak prefers to dry slowly and surface checking is a classic sign of too rapid moisture removal at the surface. Too much wind or sun and the rewetting that Dale mentioned all would cause this.
