OT: Hard disk partition question.
Don Henthorn
>I have a second hard drive that I am trying to set up as back up. At present it is not being used. My problem is that it is partitioned with one partition being set up as a FAT 32 partition while the remaining space is unallocated. I would like to to reformat the drive to make it a back up for the NTFS file system on my boot drive. How do I go about combining the two parts so I can reformat. I can't find anything in disk management that will do that.
Re: OT: Hard disk partition question.
Curly Smith
>You'll need to delete the FAT32 partition and then create a new NTFS partition using the option "use all available space". You should have a copy of "fdisk" on your PC somewhere. If not, try looking here for a suitable drive utility:
Drive Utilities (Many drive companies also have utilities that you can download, I know Western Digital in particular does, for their individual drives.)
NOTE: I'm sure you know this but when playing with fdisk, or similar utilities, check, recheck and then double-recheck that you're working on the correct drive. Any errors are non-reversible.
One suggestion *LINK*
Curt Harms
>Hi Don
I use BootItNG for partition management. It's not real intuitive or user friendly, but the price is right (it's shareware) and it seems very powerful. It will convert partitions among several file types (NTFS, FAT, FAT32, EXT2, EXT3 plus a bunch more. It will delete partitions, slide partitions, expand partitions etc. When doing this, it's a REAL good idea to have a usable backup. BootItNG has an image and restore utility but I'm not sure if that works in the shareware version or if it only works with registered copies. I use Image from the same company and I've restored several active partitions with no problem or loss of data. Address of the company is below.
Hope this helps
Curt
Terabyte
Bill Howatt
>Don,
I think since it isn't the boot drive you can use XP's Disk Management to delete the partitions and then reformat it as one NTFS partition.
Go to Control Panel Administrative Tools Computer Management
In the left pane under Storage you'll see Disk Management.
Easy to see if it does it for you.
Bill
Thanks, but the only option
Don Henthorn
>disk management gives for the unallocated space is to make a new partition. Disk management will also let me reformat the other partition but not the whole drive.
Thanks, but disk management does not give me the
Don Henthorn
>option of deleting the unallocated Fat 32 section.
My bad. It is just unallocated space, no FAT 32.
Don Henthorn
>The one partition is FAT 32. I guess if I deleted that partition maybe the drive would be available for reformatting. I'll try that. Thanks, everyone. This stuff confuses me.
Re: My bad. It is just unallocated space, no FAT 3
Bill Howatt
>That's exactly what you have to do. Once you have it designated as unallocated space you can partition it and format it as you wish.
Bill
Looks like that did it. Now,
Don Henthorn
>when I format is it a good idea to enable file and folder compression?
Re: Looks like that did it. Now,
Bill Howatt
>I never do since I always have lots of disk space. I always try to keep it simple. I also think that you can enable compression later if you wish but since I don't use it, I'm not sure.
Also, if you are storing lots of photos or video files on the drive, they are already compressed so compressing again does nothing for you.
Bill
Thanks Bill. I will skip that.
Don Henthorn
Just looked
Bill Howatt
>If you right-click on a folder in Explorer and select Properties it brings up a screen with an Advanced button on it. Click it and it will bring up an option to Compress the folder and also to Encrypt it if desired. The Compress option is available in both XP Home and Pro but the Encryption is available only in XP Pro. It is there but greyed-out in Home.
So you an compress a folder or folders later if you wish.
Bill
Re: OT: Hard disk partition question. *LINK*
wilbur
>If you're on the geeky end of the bell shaped curve, try System Rescue CD. It is a Linux based LiveCD, which means that you can stick it into your CD drive, and boot off of that. It includes a utility called GParted, which is a graphical utility that manages partitions. Wiping out your FAT32 partition and setting up a single NTFS partition should be a piece of cake.
System Rescue CD
Ok. Now this gets to the heart of my ignorance.
Don Henthorn
>Say I get Norton Ghost and get an image of the disk with all my OS, programs and data moved to the backup disk; can I then reformat the main disk and install a new WinXP and a second Linux OS along with reinstalling the programs I have. Can I then drag and drop the data folders from the back up disk to their respective programs on the main disk, or how do I handle that?
I'm a long way from leaving the first
Don Henthorn
>standard deviation at the beginning of that curve, Wilbur, as far as computer savy is concerned. I have been reading up on Linux and intend to double boot it as soon as I get this basic modification accomplished, if I ever do. Trying to decide between ubunto and kubuntu. Will that CD work for WindowsXP?
Re: Ok. Now this gets to the heart of my ignorance
Bill Howatt
>I don't use Ghost but the normal way of doing what you want to do is to setup a partition for XP and a partition for Linux. You could then restore your Ghost image of your XP system to one partition - it should handle the different size partition as long as it is big enough to hold everything. This would put you back to having your old XP system in that partition with your data files and applications.
You would install the Linux in the other partition and whatever Linux apps. You will also have to accommodate a dual-booting setup so you can decide which one you want to run at bootup. I personally avoid dual-boots but lots of people do it.
IMO, you would be wise to get your data files out of the same partition as the OS. This lets you screw up the OS without having to worry about your data files.
Bill
Re: I'm a long way from leaving the first
wilbur
>Actually, for this purpose, the only geek factor needed is being willing to type some commands in from a DOS-type prompt to get GParted going. If you can do this, you'll be able to deal with System Rescue CD.
Don't let the fact that this disk is Linux based scare you off. All you need to know is instead of booting Windows off your first hard drive, and trying to format your second hard drive, since a Linux operating system is on the CD, you boot off the CD and your two hard drives become "second" and "third" hard drives.
Once you get GParted running, the program is almost a clone of Partition Magic, the Windows disk partition program. Except that the System Rescue CD is free, minus the cost of a blank CD, instead of the $60-70 that Partition Magic runs these days.
GIve System Rescue CD a try. It is easier than I made it sound.
Imaging vs Backups
Curly Smith
>First, read this article to determine if you want/need imaging software or backup software
Imaging Software vs. Backup Software�Which is Right for You?
If imaging, this article reviews the various imaging software:
Disk Imaging Software Review 2007
This article reviews Ghost 10, note the difference in user vs editor opinion (editor - GOOD!, users - sucks)
Norton Ghost 10
You might refer to this page for free stuff (I use DriveImage) to see what you need, like, etc before buying something. It also has another description on the difference in imaging and backup software. Make sure that you understand the difference as they're not the same.
Free Hard Disk Backup and Restore, Hard Disk Image and Cloning Utilities
For what it's worth, in addition to DriveImage mentioned above, I use an older version of Ghost for imaging my hard drive and backup software that monitors my data directories. Ghost will enable me to restore my hard drive exactly as it was as of a certain date, the backup software will enable me to recover an individual file. If you're wondering why I use DriveImage if I have Ghost it's because I'm paranoid and DVDs are cheap. It's simply another way to ensure that I'll be able to recover my system after a catastrophic failure.
You guys are great. Curly I appreciate the links
Don Henthorn
>and will read them immediately to try and modify some of my ignorance.
And ,Wilber, I will give the cd a try.
Don Henthorn
>My old Partition Magic 8.0 will not work on XP and I have lost the key so I can't get updates.
