Log splitters?
Log splitters?
Log splitters?
City Slicker
>Interested in a log splitter. I've looked into Huskie, Timberwolf and Brave. Just wondering what you guys have had good luck with? I split only 4-6 cords a year, but looking for a quality splitter. Whatever I purchase, Im leaning towards a Honda engine.
Re: Log splitters?
Re: Log splitters?
Curly Smith
>Not what you were asking but how about this instead
12-Ton Air/Manual Hydraulic
I have one of their manual versions and it does a fine job for my 1-2 cords per year. Yes, it's more work than a gasoline powered model but it's cheaper, less maintenance and much quieter.
If you have a suitable compressor and power to your splitting area then maybe the air version is an option and at $350 it'd save you a bit of cash to buy some more clamps.
Re: Log splitters?
Re: Log splitters?
Pete in Holland, MI
>Many are similar. Not to worry too much about the engine. Briggs & Techumpseh (sp?) are good engines. With all engines though, only run them at about 2/3 throttle for most of your work. Change the oil regularly. Store with gas in the tank with the proper amount of Sta-bil mixed in the fuel system. Working any splitter at maximum capacity is where you run into problems.
I don't own one personally, but use one often. The type that tilt upright are really cool for large blocks of firewood.
Re: Log splitters?
Take a look see at Northern Tool.....
Scott in Eastern Iowa
>.....not sure what your "20" is but they do ship.
Might be a worthwhile search for you ?
Scott
Re: Log splitters?
Wide Range
>You can pay way too much for your needs or pay good money for junk. I have a 32 ton [6" cylander] MTD verticle/horizontal splitter. I've had it for 7 years, and have split 50-60 cords of oak, ash, hickory, elm, and assorted hardwoods from my area. Paid $1,400 for it at the Borg. The engine [8hp B&S] has been just fine; runs at 2 speeds, idle and flat out; could use a higher volume pump for a faster recycle time, but what I have is adaquate. The basic problem I have is the design defects. The 1st issue is that they used an 8" square tube for both the hydrolic fluid tank, the axle, and the motor mount. All of the vibrations from the motor and the road are thus transferred to that tank, which is a structural member, and many of the welds have started to crack and leak fluid over the years. I rewelded several of them, but found the second issue, which was the thickness of the steel in the tube. It's OK, but is rather thin for what should be the most durable part of the machine. This year I will be bolting on a new tank and putting the engine on an isolation mount. That will cure my machine's problems, and I expect at least another 10 years use out of it. Compared with the cost of renting one to do as much as I've split over the years, the one I have has paid for itself at least 4 times over; owes me nothing.
First obvious suggestion is to stay well away from units that use the fluid tank as an axle/structural element. I've since looked at several Brave units and seen both designs. I have no experience with the Timberwolf splitters, but they "look" like more machine than you're likely to need. Power lifts and multi-split wedges sound nice, but you'll be paying a pretty price for them. Note also that if you try putting interlocked grain woods like elm through a multi-wedge machine that's short of much more power than I have in mine, you'll go nowhere. Since I'm splitting only hardwoods, often in the 24-30" diameter range, I use the vertical configuration only, and drop it horizontal to move it around.
I checked the Tractor Supply site for your Huskee brand and it looks like they all use the structural fluid tank concept. Based on that alone, I'd stay away from them.
Hope this helps
Re: Log splitters?
www.supersplit.com
Kirk D.
>Awesome machine! Just split 15 cords with the jr. model. More than enough power and super fast. Bought it from the owner who actually makes the machine.
