Re: Omnijig problem
Curly Smith
>I don't have an omnijig but...
it sounds your wrench is telling you the nut/clamp is tight before it really is tight.
Possible problems:
The threads on the nuts/bolt are not in good condition. Remove them and chase with the appropriate tap/die.
The bolt is bent. Remove and verify that it is straight (if bent it's binding on the jig).
The end opposite of the clamp is not straight/square (it's binding making it feel "tight") Verify that all is in good repair and lubricate as necessary. (You could also try squeezing the opposite end with a small clamp to see if things improve.)
The bolt holes are not aligned. Could be a manufacturing defect, could be an assembly problem. Remove nuts and verify that bolt moves freely.
I hesitate to mention this but are you sure you're rotating the cam clamp in the right direction? I, of course, would never try to use one backwards but I have heard stories...
Have you tried swapping parts from the back clamp? The front clamp may have a manufacturing defect.
You could also cut a small plastic spacer to slip under the clamp after you get it mostly tight. The extra thickness should enable you to get it tight.
