Cutting a Thumb Molding Question
>I am making a dining table as a gift. I have a picture to go by that is pretty vague. It appears to have a thumb molding around the top. How would you cut it? Is there a router bit for it? Or would you just use a round over bit and then sand the profile?
Re: Cutting a Thumb Molding Question
Carol - Strawberry, AZ
>There is a thumbnail bit, Barry. It's radius is not symmetrical and it is most often cut with a double shoulder, like a bead,
The bit is a large one. You will want a variable speed router running at the slowest speed. And put your router on an offset base, to offset the weight of the router and make control much easier.
Thumbnail Bit
Charles M
>Here's the 99-027 which is Freud's version of a fairly common profile.
Charles M
Freud America, Inc.
Thanks Carol, Can you describe....
>the offset base? Sounds like a good idea. Thanks,
Re: Thumbnail Bit
>Thanks Charles, I want that shape without the shoulder. I can just run the bit shallow enough to not cut the shoulder or see if they have one that does not include it.
Re: Thanks Carol, Can you describe....
>Sure Barry. First a comment about the bit. All of the thumbnail bits look like the one Charles showed. You get a shoulder (or not) by exposure of the bit through the base. Don't want the shoulder, hold off on the exposure of the bit.
With regard to the base. First you will find plans and a drawing in my book, "Router Joinery Workshop." Second, think a pear-shaped acrylic base with a handle over the narrow end of the pear. Third, I'll attach a close-up of one that I use for hinger mortising.
Handy base to have. Inexpensive to make. I have at least one for each of my routers. I have some with varying sizes of bit holes, depending which bit I plan to use. For the thumbnail bit, the hole will be rather large. We can talk about milling that large diameter hole in acrylic later.
>Thanks again, I looked at one at Woodcraft.
Just bought the bit. The Woodcraft version was half he price of the CMT One. I hope I did not make a mistake going with the cheaper one. I see this as a once off bit. Of course, now that I have one I will probably use it everyday. (NOT)
I can make the base also. Thank's again. Yours looks better than the one at Woodcraft.
Ron
>You can also do it using hand planes. a #4 and a shoulder plane(or a dado in a tablesaw to make the inital cut. It's not that much slower when you factor in the setup time and you get more control over the profile.
Re: Thumbnail Bit
Charles M
>The step down from the top of the board is a factor of the bit height and will disappear as you raise the bit. The profile picture shows the full depth of cut.
Charles M
Freud America, Inc.
wayne
>You know I was pondering that same question this past Sunday. I was working with my saber saw and cut the inside of my thumb, though it wasn't molding yet, I didn't like the color of the stain but it was very loud, correction I was very loud.
