Jet 14" Bandsaw Restoration Finished...
Dave Morris
>... or more to the point, this old Wood/Metal Bandsaw has reached the level of "working tool" again. Many thanks to the members of this forum for their advice to my questions and the info I found in their posts in the archives.
The saw was a real basket case when I got it, a lot worse than I originally thought. Many things became apparent only after tear-down. The tires and wheel bearings were shot, some rusted parts, a bent lower wheel, the blade tensioning device was busted, no fence, the upper wheel cover was bent and rubbing the upper wheel, the motor mounting bracket was a rusted joke, the base cabinet was all wobbly and weak, the doors on the cabinet wouldn't hardly open (the sheet metal was bent and the hinges were all tweaked), the door knobs were stripped, the wiring was all corroded and totally shot, the original power ON/OFF switch was busted, the blade guides and bearings were all shot, the speed-changing shaft was totally ground up and hanging from it's bearings (NOT good), it was covered in crud/dirt/grime/acid drippings and bird stuff(?), and everything was in a very sad state of repair.
Each time I found something new wrong with the saw, I got more determined to not let it beat me. Dumb? Maybe. Stubborn? Definitely. But in the end I have a better-than-new saw, and I learned a lot more about the saw's inner workings than if I had simply purchased a new tool. But WHY restore an old 14" Jet? Well, I figured I would learn more about what I want and need in a band saw if I restored an old junker. That way, when I have the long green to purchase my "Dream Saw" in the future, I'll be better able to make the right decision for my specific needs. Also, I'll be much better able to determine what condintion a more expensive saw is "really" in, should I buy used.
This saw got a full tear-down, cleaning, all new bearings and (available) parts. Added a link belt and the Kreg fence. Fixed a broken table hand knob with JB Weld (worked great). Reinforced the base cabinet with 3/4" plywood on the inside, designed a new motor mount that slides back and forth for more versatility in blade speed choices, added a 110 volt power outlet for a magnetic task light, and a better switch in a more convenient location. New Iturra Spinner and spring for blade tension. Added the riser block, and removed the locating pins in both the riser block and the lower frame casting so I could adjust the position of the upper frame (now the wheels are pulled "into" co-planer alignment under tension). Had the trashed speed-change shaft replaced (it wobbled a good 45� in what was left of it's bearings, how could somebody continue to use the saw in that condition???) with a new machined shaft and bearings, and it now works perfectly. I had a new guide bar made from some old 15/16" hex stock, since the round bar that came with the new riser block would not fit this old saw. The Kreg fence needed a piece of 1.5" angle stock to mount it on the table, and I filed a slot in the angle stock to clear the table's miter slot. Left the old miter gauge alone, it's resting in it's slot for the picture, but my Incra 1000 will see duty there when it's needed. I fixed the bent lower wheel as best as I could so there is only a couple hundredths of an inch of side-to-side wobble, hopefully that won't be a problem as new replacement wheels are no longer available. Anyway, the saw runs pretty smooth and (barely) passes the nickel test. Still planning on balancing the wheels when I get the time, and a new set of balanced steel pulleys wouldn't hurt either.
Colors are pure Rattle-Can... a coat or two of primer, then Rustoleum Silver Metallic for the frame and table support, Dark Machine Grey for the wheel covers and table sides, Hammered Black for the base cabinet. Left the guides, guide bar, and hand knobs unpainted, but simply cleaned and buffed, and scrubbed/sanded/polished up the table surface just enough to remove any rust, but still leave a little of the old patina. It's an old tool, and I wanted the table to reflect that (or to "not" reflect that, as the case may be). A coat of Johnson's paste wax keeps the surface nice and slick.
This is the first time I've restored a tool, so please forgive any mistakes I've made along the way. Yeah, it took a lot longer than I thought, was more complicated than I originally planned, generated a lot of head-scratching and no small amount of muttered cussing, and used quite a few of the limited free hours I have available for shop time. But was it fun? You betcha!
Now to start making some wood dust. Anybody got some ideas for a folding outfeed table with adjustable support legs? Nothing shows up in a search for bandsaw outfeed tables (lots of tablesaw outfeed stuff though). I've got a bunch of 2-3" thick, 6" wide, 5-foot long curved barrel staves from some old redwood wine vats I'd like to resaw into straight stock for some Adirondack chairs as a gift for my lovely wife. I figure she's earned it after putting up with this project. ;-)
Thanks for looking.
Dave--- who hopes this "Pic" thing works out, since he's never added a picture to a post before
