cutting foam
mike mcnerney
>I have a tempur mattress, queeen size, 10 x 60 x 80 & am considering making it thinner, in order to hopefully reduce it's ability to insulate the bodies heat, it's just too hot. I am thinking about getting a band saw blade like the type they use to cut fabric with, or maybe even a 3 tpi & making an 8 ft bow saw. Lay the mattress upside down & build a frame about 5 or 6" high & using that as a guide to saw it.
First question, do you think that will work.
second question do you think it will solve or significantly reduce the heat issue.
third question, how much ventilation underneathe the bed, either holes or slats would help. right now it is sitting on ply with holes on a metal frame, but eventually, I would like to make a box with drawers, knowing I would have to create an airspace of some amount, say 2 to 4". I even wondered about putting some small computer type fans in that space?
The company is useless with advice, they just tell you the waranty would be voided. This mattress is really helping my back problems.
thanks
mike mcnerney in ottawa
