shaper powerfeed
shaper powerfeed
shaper powerfeed
Eddie
>I am new to the process of setting up a powerfeed on my 5hp shaper, can anyone give me some pointers.....thanks so much.Ed
Re: shaper powerfeed
Keith Newton
>It would help whomever responds to know what shaper you have, and which feeder, and even if you have a special fence.
frank shic
>bore the holes on the shaper top, tap, and bolt the powerfeeder arm - don't worry, you probably won't ever move it again in the future! aim the feeder slightly inwards at the fence.
mounting shaper powerfeed
JRutter
>I've got feeders mounted to tapped holes and feeders mounted to through holes with nuts. If you have a tap, go for it - it is easier than getting a wrench underneath in a tight spot. One advantage to through holes is that you can usually swap feeders in the future and keep the same holes. Most bases only vary by a small amount in hole pattern - German, Italian, Taiwanese, etc.
Make sure you are not drilling into ribbing or right over the base edge unless you will be tapping.
Pay attention to where the tightening lever on the base ends up in relation to the fence and the horizontal adjustment wheel. I like it to be on the outside end, maybe even with the base at 45 deg. to the table so the lever is not obstructed by anything.
Befre drilling, test the feeder at 4 different positions: edge feeding against the fence R-L and L-R, and table feedeing R-L and L-R. For a 3-wheel feeder, you generally want 2 wheels before the cutter.
If you will be switching between feed directions for different cutters, a 4-wheel feeder is much easier to pivot to get the toe-in right and keep 2 wheels on each side as opposed to cranking the horizontal arm back and forth AND adjusting the pivot.
Finally, if you will be adding another shaper, or some other tool that would benefit from a feeder, put it on the corner of the shaper where it can pivot over to the second machine. I used to have a setup where two shapers were set up at 90 deg. to each other. One feeder pivoted between the two.
