Have a question? Ask Woody!
OT - Printer (cont)
OT - Printer (cont)
OT - Printer (cont)
Robert R Clough - Thorncraft
>The post below by Joanne re: printers. All of you talk about Lasers and Inkjets. As you may remember my Samsung is J.U.N.K. and I must get a new printer. I have been looking at an HP Officejet Pro L7500 ($299). It appears to be a combination inkjet and laser; laser for B&W and inkjet cor color. The cartridges are reasonably priced.
Am I correct in my reading of this? If I don't use color every day, will the jets dry and clog? And any other answers you might have for questions I can't think of.
Re: OT - Printer (cont)
Hoa Dinh in Alameda
>"...HP Officejet Pro L7500 ($299). It appears to be a combination inkjet and laser; laser for B&W and inkjet cor color."
Not from HP's website. These are taken directly from there:
- Print technology: HP Thermal Inkjet.
- Print quality like a laser. Just faster.
- Breakthrough inkjet draft mode speeds�up to 35 ppm black and up to 34 ppm color.
The "accessories" page list only HP 88 Ink Cartridges, no mentioning of laser cartridge.
David Sparks
>I have an old HP PSC 500 All-in-one that goes for long periods of time without being used. I haven't had any problem with the ink drying up and clogging. It may happen, but so far I've been lucky.
Bill Howatt
>I have a now old Epson 740 that never clogs either. I use a HP Laser for my B&W printing which is by far the bulk of it; I only turn the Epson on to do photos. One thing that minimizes ink problems is to make sure you always turn the printer off when it is not being used so it properly parks the cartridges. I also only use Epson ink.
Bill
Curly Smith
>You might try perusing this site: Reviews and advice on printers
They've got buying guides, editor's choices and all of that other good stuff (check the left side of the page). The L7500 you refer to belongs to the family reviewed here: HP Officejet Pro L7580 All-in-One .
I'm not sure that you're going to get the printer help that you're looking for here. You're going to see folks fairly equally divided on the "clogged jets" issue. I'm in the camp that inkjets are poor choices for infrequent use but others clearly have very different results. It may have something to do with humidity (I live in a dry climate), it may have to do with a specific printer (I've had the same problem with different printers), it may have to do with a specific manufacturer (I've had the same problem with different manufacturers). I should mention that I've had no problems when the printers were used daily (or at least a couple of days a week).
If you're going to buy an inkjet there are a couple of things that you want to look for:
a) Separate ink supplies for color and B&W. This used to be a fairly big issue but I think it's pretty much the standard now.
b) Print heads on the cartridges help solve the clogged jet problem. If you can't resolve the clog by wiping with a damp towel or soaking in water then you can replace the cartridge. The cartridges are more expensive but it may be cheap insurance.
c) Easy way to clean the print head. A regular PM schedule of cleaning might be helpful. All printers have a self-cleaning mode, it's just easier to find on some models than on others.
If you need inexpensive color then an inkjet is the only viable option. If you can live with just B&W then I'd go with a laser.
