200+ woodworking book reviews
bench tools on mechanics rollaways?
billfrommich
>Has anyone tried mounting "bench top" sized power tools (lunchbox planers, belt/disk sanders, grinders, bench drill presses, mortising machines, etc.) on top of those metal, multidrawer, "rollaway" mechanics tool chests sold by Craftsman/Sears, Kobalt/Lowes, Husky/Home Dept, etc. In my small shop I would like to use the space under these tools for storage and yet retain some mobility - the tool chests (perhaps with some modifications) might provide a readymade staring point. Any ideas on potential "pros and cons" ? Thanks.
Re: bench tools on mechanics rollaways?
Rattlemania
Re: Rattlemania
billfrommich
>Yeah, I had thought of that! I figured I would definitely need to have to have some type of resilient draw lining material and be selective about what was stored. Also, while I figured to use a thick plywood/mdf top to serve as a mounting base for the tools, perhaps some sound/vibration dampening material between the plywood/mdf and the sheetmetal would be in order.
wcandres
>I mounted my router table on top on one. Put rubber pads in the drawer bottoms and it takes care of the noise. Works well. Out of the way quick and easy.
Bill
Carol - Strawberry, AZ
>I have an SCMS on top of a HF box. Truly flimsy compared to the Grizzly boxes I have. I put the rubber waffle stuff RV'ers use to keep the china from sliding around in the drawers. More than adequately muffles the noise. The drawers get full of sawdust more than I'd like, but that is only my real complaint. It would help if I made a better effort to keep thementirely closed! :) As for sturdiness, the whole set up works just fine, especially with some weighty item in the bottom.
Pat Mulligan
>I keep most ofmy turning tools that aren't the main three or four users in a rolling toolbox. On top of that is a wilton belt/disc sander that I use for sharpening in between rare trips to the grinder. I can keep things at arms reach and save a lot of steps every day.
So, by extension...
Denis Ch�nard, Orl�ans, Ont.
>If we had a bunch of little red bugs with black dots on mechanics rollaways, we'd call that Beetlemania? :-)
DC
Alternative
Bob Fawcett
>I have my lunchbox planer mounted on a rolling stand with a flipover top. I put my 6x48 belt sander on the other side of the top. This puts 2 tools on one stand.
Neal in San Jose
>My rolling drill center is shop shot 79 from 6/9/99. Initially made to hold my bench top drill press, I've since added my hollow chisel mortiser on the back, so I get two tools in the floorspace of one. Drills, bits, hollow chisels, etc. are all stored in the drawer or in the cabinet below. It saves floorspace and time.
