It depends
Curly Smith
>Ditto what Mark said above but I'll add a few comments:
- If you use the printer every day (or every other day) then an inkjet printer can be a good choice. Inkjets are horrible choices for infrequent use as the ink will dry out and you'll discard a partially used, and expensive, cartridge. In addition, infrequent use leads to clogged jets, meaning you'll fight the printer every time you use it. FYI, your old printer was much more forgiving than the new printers.
- If you buy an inkjet printer try to buy one that can use "after market" cartridges. Look at the printer supply aisle in your local office supply store and verify that the generics (or refills) will fit your printer. You don't want to get locked into a sole supplier that might decide to discontinue making the cartridge or that charges a premium price.
- Laser printers are much cheaper to operate "per printed page" than inkjet printers but they cost more to buy. Laser printers also print faster and are quieter (generally speaking).
- Inkjet printers are cheap since the money is in the refill cartridges. However, you can get a color laser printer for free if you buy the refills from the manufacturer. It's the same business model as the inkjets but I don't know how cost effective it really is. If interested, visit the Xerox website and look for the Phaser printers.
- Want an inexpensive printer? Check the police auction websites. Also check the computer clearinghouses for discontinued models BUT verify that you can get supplies before you buy one.
- Printers don't come with a printer cable and new printers generally connect via a USB port or a network connection. Make sure your PC has a USB port, a network card, or that you have the necessary adapters. It's all more money that you didn't want to spend.
- Color is expensive, stick to B&W unless you really need color.
Personally, I use a B&W laser printer and take my digital photos, and other color printing needs, to a print shop. It's the most cost effective for me, YMMV.
