Using old scraper blade
Don Henthorn
>A while ago I posted about making some scraper blades for my rusted old Stanley no.80 scraper. I have just not ordered the steel, but the other day I got antsy with nothing to do and got out the old scraper. Looked pretty sad, but I found that removing the rust wasn't much of job and it didn't look too bad. Then I took a look at the blade which I knew was pitted. One edge was bad, but the other looked like it might be made to work. I got out the stones and oil and brightened up the edge that looked salvageable. There was some pitting near one side but I figured that the bend put in the scraper might put the pits out of the cutting area, so I proceeded to grind the 45 degree bevel nice and true. Honing both surfaces proved a little challenging as I am not as steady as I used to be but I managed to get them pretty well polished and then drew the edge and turned a slight butt. Man!!!!! It only took a couple of hours to scrape the whole cedar chest and it was easy work. Below is a picture of the process. The chest belonged to my Mother. It was made in Wisconsin and was purchased between 1915 and 1920. I am refinishing it so it will be in good shape to turn over to one of the kids in a few years (hopefully (G)).
