Tiny Lil' Breadboards - Update
Scott in Douglassville
>Hi, all -
Ok, to follow up on my earlier post, I finished the breadboard ends on the mahogany lensboard I'm making:
Actually turned out to be pretty straight forward, if diminutive. Milled the stock to about 3/8", installed a general purpose 7-1/4" blade from my circ saw on the tablesaw, which cuts a significantly thinner kerf, but was rated for the same max speed as my tablesaw blades, ran a groove down the center of the edge, flipped the board end-to-end and ran it again so I'd have a truly centered groove. Ended up just at 3/32". Milled the matching tongues to fit on the horizontal router table. Easy peasy. Glued them up last night with poly glue on the center ~3" or so of the joint. They're tight...
Thanks for the help.
Scott
