Veritas - Innovation in Tools
Glue Squeeze out question?
>When I use glue to edge joint or almost any other application I look for squeeze out. Usually coat both surfaces and clamp up. I look closely for the squeeze out. I'm not happy if I don't get at least a little. What I'm wondering about is what percentage of the glue gets scraped off and thrown in the trash? This is sort a silly question, but I spend a lot of time dealing with it, keeping it off the surface, taping joints with masking tape and I throw it away after creating it on purpose. I think I may throw away most of the glue I "use". What do you think?
Re: Glue Squeeze out question?
Putting the Squeeze on Elmer Titebond
>Well Barry,
Your question reminds me of my wife, in a way. She can worry about anything, and I am occasionally amazed at her choice of worrysome item eligibility. She has invented many excuses for worry, but never glue. I will suggest she focus on that for awhile. :<) I never questioned the amount of glue utility loss due squeeze out anymore than the number of synthetic sponges expended wiping up after the escape of renegade Titebond. A former employer remarked to me one time that "glue ooze was sanctified", and I took that to mean it was perfectly alright to use just enough glue in a project to result in residue cleanup afterward. Thus, a little squeeze out is okay, and a welcome portion of your total resource expendature.
George
Bob Lang
>I think the "insurance" of having glue squeeze out is far outweighed by the mess it creates. I was taught, and I try to achieve applying enough glue so that it "almost" squeezes out. Modern glues are very strong, and I contend that if you have 90-95% glue coverage, you have enough to get a bond "stronger than the wood itself". Although I am a frugal person, and don't like wasting glue, my main reason is to save time and effort. The easiest mess to clean up is the one I don't make.
my $.02
Bob Lang
Pete LaBelle
>Boards ------------------------------------------------ $20
Glue used --------------------------------------------- $0.10
Glue scraped off & thrown away ------------------------ $0.04
A joint that won't separate due to too-little glue ---- Priceless
Worry about things worth worring about life.
My 3 cents worth (adjusted for inflation)
Pete
And.....
>How much gas is left in the tank when the prop stops turning?
Clint
Dale Lenz
Re: WAGuessamation
Dale Lenz
>Probably 25~33% of my glue gets squeeze-out and drips gets put into the wash can during clean-up. I figure for every $10K of work I use one quart of glue. So......7 dollars worth of glue/10,000 x 100 equals something like .07%. So therefore, 1/3 of my 7 dollars glue is "wasted", $2.33. Damn the torpedoes - full speed ahead!, :~>.
Now ask me how much soap and water I use to save a ten cent acid brush, : ' >.
Now, my marketing cost is 15%, $1500 out of ten G. With all due respect, that's something to dwell upon.
Have a great day,
Dale in the shop today, YEA
Larry Clinton At Frankfort (Central)., Indiana
>I waste a bunch - probably over 10%. However, I feel better about this waste than the gallon or two I will throw away due to being out of date. Right now I have 2 - 1 gallon containers of glue - 1 Titebond 3 and 1 Lee Valley Cabinet glue, both have at least 3 quarts left and are about 6 months old, 1 small container of Gorilla glue, 1 8 oz bottle of liquid hide glue (about to throw away) and one 16 oz. container of Liquid hide glue new. I won't use glue over 12 - 14 months old even though I keep my shop at 55 to 75 deg year around. I won't risk of having a joint fail on a project that I spent weeks on, to save $10.00 ~ $20. To me it is like using pine on a 20 bf project you spend 120 hrs on. The cost of using Oak or Cherry may be $60 to $100 more - I'm not willing to build something with inferior materials to save $.50 to $.75 an hour of shop time.
Jim Dillon
>Barry,
Actually, I find it comforting to see a little (emphasis on little)glue squeeze-out on a joint. I get worried if I don't see any squeeze-out and wonder if I have a dry-joint in that specific area or along the whole joint if it is a long board. Yes, it is a mess to deal with, but I would rather have just a little too much, than too little. Having said that, I treat mortise and tenon joints differently and shoot for virtually no squeeze-out. Just some thoughts.
Jim
>Better squeeze out than a starved joint! If you really want to do some investigation, you can weigh the joint before and after and measure what you wipe and scrape off :). You can try out some of the fluorescent Titebond for a better estimation.
I Wonder If Glue Squeeze Out Can Be Returned
>to the bottle for re-use.
